Author Topic: Problem with 03 sahara...noisy throw-out bearing?  (Read 1220 times)
Matty__e
« on: January 08, 2008, 09:40:08 PM »
well  recently picked op this jeep about 3 months ago, and really been loving it.  I have noticed out the past month a crunching?!? noice when i engage the clutch.  At first i was thinking it was just in hinge that the pedal is attached to in the firewall.  After further I found the noise is coming from the front of the tranmission casing where the throwout bearing is.  Anyone heard of this problem before.  I am a new jeep owner and also learning the setup and so on.  Any ideas?
Offline BrokenAxle
    • Broken Axle home page
Re: Problem with 03 sahara...noisy throw-out bearing?
« Reply #1 on: January 09, 2008, 12:06:58 PM »
from your description it very well could be the throw out bearing.  if you need to get it done, i do some work out of my garage.  let me know.
Dave
« Reply #2 on: January 09, 2008, 03:03:44 PM »
Run it until it starts to squeel like a stuck pig. Then do a complete clutch job while you are in there.
Sometimes they run for several years while groweling, sometimes they go in a couple months. Problem is, the labor to do a release bearing is essentially the same as doing the clutch as well. 6 less bolts. So you might as well stretch it out, and then do the clutch when its time.
Good luck.
Offline 01sahara
« Reply #3 on: January 09, 2008, 03:06:26 PM »
Good luck.
The bearing in my 2001 Sahara  has been making a little noise for 2 years and has not got any worse durring that time.
« Reply #4 on: January 09, 2008, 04:03:02 PM »
I ran mine with a squeeky throw-out bearing for a good 6 months before i changed it.  It got pretty bad, so I thought it was time to change it
Dragonmaster
« Reply #5 on: January 09, 2008, 06:41:25 PM »
Sounds like you are describing exactly what mine did.  $283 for the whole clutch assembly and a day under the jeep in the driveway and you can have a whole new clutch and throwout bearing.
Matty__e
« Reply #6 on: January 09, 2008, 10:02:32 PM »
Dave
Thanks for the offer.  I currently have a place with garage and kinda love to tinker around with these sorts of things.  When the time comes i will keep you in mind whereas it may be nice to get some assistance with the project.
Matty__e
« Reply #7 on: January 09, 2008, 10:06:21 PM »
thanks for all the input.  Yea i guess I will let er go until it started to drive me nutts.  should i feel this in the clutch when i engage and disengage the clutch.  I did have a quick look under and relized that it would a big job for just the bearing and it definately would be smart to change the cluth at the same time.  Thanks again for the help.
Offline BrokenAxle
« Reply #8 on: January 10, 2008, 12:20:35 PM »
no problem.  and i definitely agree to do the whole clutch while you are in there.  also i like to get the flywheel machined.  chances are nothing will happen if you don't but if something does you'll be kicking yourself for it.
