Author Topic: New to forum... question time.  (Read 1303 times)
« on: January 13, 2008, 02:38:55 PM »
Hey all,
New to the forum, just wanted to run some questions past ya.
Have a 99 WJ (staying stock), just bought a 99 XJ for fun. Plans are are a 5" lift, 33", bumpers, winch, lights, CB. My question (albeit a broad question) is.... What problems arise when doing the lift/tire mods on a Cherokee. I am thinking that I will have to regear. Any recommendations?
T
Offline BrokenAxle
    • Broken Axle home page
Re: New to forum... question time.
« Reply #1 on: January 13, 2008, 09:39:15 PM »
regearing is probably a good idea - you'll be happier.  you may need to do a slip yoke eliminator - definitely recommended.  adjustable control arms or maybe some relocation brackets.  you will have to do some fender trimming to fit those 33s.  upgrade your track bar - some kits come with one.  get a good steering stabilizer.  bar pin eliminators are a good idea in the rear aswell...
« Reply #2 on: January 13, 2008, 11:31:16 PM »
Thanks!
At the risk of sounding like a complete newbie... what is a bar pin eliminator? What gears are recommended for 33"?
T
Tribal Jeep
« Reply #3 on: January 13, 2008, 11:57:29 PM »
Thanks!
4.27 or 4.56 - 4.88 incase you decide to upsize to 35's or 37's at  a later date.
check out this size to ratio graph
http://www.4lo.com/calc/geartable.htm
Offline BrokenAxle
« Reply #4 on: January 14, 2008, 01:08:10 PM »
at the top of your shocks in the rear there is a bar that goes through the bushing that gets bolted to the unibody.  the bar pin eliminator is a bracket that bolts to the body and then the shock gets bolted to the bracket.  its just a weak spot the bar can break or slip out from under the bolt. plus if the bolts haven't been out for a while they can be a bastard to get out.  it isn't a crucial upgrade, just a peace of mind upgrade...
« Reply #5 on: January 14, 2008, 01:23:07 PM »
Thanks!
T
For 33s, 4.10-4.56 gears work pretty good.  I run 4.10s with my 33s in my YJ and I have a good amount of power.  If you are thinking you might go to 35s, then go with the 4.56s.  4.88s would be pretty steep for 33s unless it has a 4 banger
« Reply #6 on: January 14, 2008, 02:08:22 PM »
33's & 4.10's here and it's not very nice.  going 4.88 and will test em with 33's before i decide if i want to go with 35's or not.
Offline BrokenAxle
« Reply #7 on: January 14, 2008, 04:13:01 PM »
gearing also depends on manual or automatic transmission.  you need a numerically higher gear ratio with an auto for the same results
« Reply #8 on: January 14, 2008, 05:27:38 PM »
Sweet!! You guys rock.
I had more questions to ask slow day at work), but I can't remember them right now.
T
