Author Topic: T-case regearing?  (Read 1332 times)
T-case regearing?
« on: January 19, 2008, 11:52:11 PM »
Has anyone regeared the T-case gears instead of the other gears?
T
Re: T-case regearing?
« Reply #1 on: January 20, 2008, 02:47:31 PM »
Yeah I got the tera 4:1 in my t-case.
« Reply #2 on: January 20, 2008, 04:17:58 PM »
How is that working out for you?
Did you regear the axles as well?
Offline Rookie
« Reply #3 on: January 20, 2008, 07:12:17 PM »
re gearing the T-case only helps you in 4 low in 2 high and 4 high its still a 1:1 ratio
If you need to compensate for larger tires you need to re gear the axles
TJ with some stuff
« Reply #4 on: January 20, 2008, 07:20:41 PM »
Dang-it, I guess there is no way aroung regearing the XJ for 33"s. thanks guys.
T
« Reply #5 on: January 21, 2008, 07:23:35 AM »
I already had 4.10s in my axles so I did not need to re-gear, and Rookie is right the t-case gearing is only good in 4low
Tribal Jeep
« Reply #6 on: January 21, 2008, 08:34:58 AM »
ever heard of the Klune-V Extreme Underdrive system? Its an extra gear box that bolts on. When mated with the NP231 it is capable of 11:1 low ratio!
I know this wouldnt help you but thought id throw that out there.
« Reply #7 on: January 21, 2008, 01:54:13 PM »
I have 4.56 gears and Teralow 4:1 like Black YJ...
It gives me about a 73:1 crawling ratio on first gear.... It's good enough for what I'm doing.
I run 37" tires on that set up. ...
I like the Teralow system. I added 2 low when me and a buddy were building it.
It's a little slow for winter wheeing though
