Author Topic: jeeps hate me  (Read 2044 times)
jeeps hate me
« on: January 22, 2008, 09:29:21 AM »
 ok, so. heres whats going on. after i have been driving a while and engine is nice and warm, I am getting what seems to be bad misfires. the rpms jump back and forth and i have no real throttle input. when i pull over and just rev the engine i can hear it backfiring pretty bad too, all in all it sounds and feels really crappy. at first it feels like the tranny is slipping, however, when you just rev the engine in neutral, you can feel it shudder and the rpms jump, or die......
history; jeep ran when i bought it, but died soon after. replaced ignition coil, crank position sensor and then the camsensor/pickup coil in the distributor. after that she fired right up. jeep runs fine until its gotten warmed up and stuff..... any ideas? its a 95 with the 4.0l
will do plugs and wires tonigth..... throw in new dist. cap and rotor as well.....
Re: jeeps hate me
« Reply #1 on: January 22, 2008, 09:41:12 AM »
my safari does this once or twice a year.  either it eventually stalls and is good again or i shut it off, restart and its good again.  it is also a 95 hrrrrmmm.  anyhoo no idea why.
how long does it last for you?  or just continuously once warm?
Re: jeeps hate me
« Reply #2 on: January 22, 2008, 10:39:44 AM »
first time i just restarted it, played with teh throttle cable again, and it ran good. last night though, i let it sit for 5 mins, fired her up, and it still did it...... so i'm stumped
Offline EVOLUTION
    • EMF Rod Ends Website
Re: jeeps hate me
« Reply #3 on: January 22, 2008, 11:28:02 AM »
The only thing I can think of is you are getting backfiring & throttle problems due to incorrect timing.
Before going out & spending a bunch more money on parts you dont need, try adjusting the timing and see if it helps.
Also check your wires & plugs.  If you look in the wire boot & you see a sort of "ash" stuff, then it is probably a wire.
« Last Edit: January 22, 2008, 11:39:02 AM by fragz »
Evolution Machining & Fabrication  403.935.3540
Evo Forums:  http://www.evolutionmachining.com
Evo Joints website:  http://www.emfrodends.com
Facebook Page:  http://www.facebook.com/EMFRodEnds
Offline 4PLAYZJ
Re: jeeps hate me
« Reply #4 on: January 22, 2008, 06:25:56 PM »
did you replace the wires?  You can test them with water.  Get your engine warm the soak the wires with water from a spray bottle.  When wires get hot they dont insulate as well and the water will act a a conducter and show any spots with weak insulation.
Trouble Maker
Re: jeeps hate me
« Reply #5 on: January 22, 2008, 08:50:21 PM »
 The below was stolen shamelessly from jeepforum.com, it is for newer 4.0L  but most probably still applies. Might be a good idea to try the Mopar Combustion Chamber Cleaner.
4.0 Engine misfires
Models affected (applies to vehicles equipped with a 4.0L engine):
1999-2001 (XJ) Cherokee;
1999-2004 (WJ) Grand Cherokee (All Markets);
1999-2004 (TJ) Wrangler; and
2001-’04 (WG) Grand Cherokee (International Markets).
The customer may experience an incident of engine misfire during certain vehicle operating conditions. The misfire may occur when the vehicle is operated between 50-70 mph and under light loading conditions, e.g. slight uphill road grades. This condition may occur at all ambient conditions, but is more noticeable when ambient conditions are less than 0° C (32° F).
If the vehicle is OBD equipped, an MIL illumination may also have occurred due to DTC P0300 - Multiple Cylinder Misfire. Various single cylinder misfire DTCs may also be present. If the frequency of misfire is high, the PCM may place the engine in “limp-in” mode.
The misfire condition may be caused by one or more engine exhaust valves that are slow to close. Late closure of an exhaust valve may be the result of no valve rotation and associated buildup of carbon on the exhaust valve stem.
DIAGNOSIS
1. This condition may occur when the engine is not allowed to run at engine rpm that are greater than 3,200 rpm. At 3,200 rpm or higher the engine exhaust valves will rotate if not impeded by high carbon deposits. Low engine rpm and high carbon deposits are associated with short-trip driving where the vehicle engine is not allowed to fully warm to normal engine operating temperatures. Cold ambient temperatures will increase engine warm-up time and add to the opportunity of carbon deposit buildup on the stem of the engine exhaust valve.
2. Verify that an engine misfire condition is present. Use of the DRBIII during a road test, or a Co-Pilot data recording, may help to determine engine misfire and misfire counts. If carbon deposit accumulation is severe, then a cylinder leak down test may detect one or more cylinders leaking greater than 15%. Save any misfire DTC freeze-frame data that was stored for later misfire correction verification.
3. Verify that the engine misfire condition is not caused by faulty engine mechanical or electrical components.
4. If the engine mechanical and electrical systems are operating properly, perform the Repair Procedure.
REPAIR PROCEDURE
Inspection:
1. Raise the vehicle’s hood.
2. Remove the engine valve cover and all six exhaust valve rocker arms (the intake rocker arms are also removed during this step). Refer to the appropriate vehicle service manual for detailed removal instructions. The valve cover gasket is reuseable. Keep each pair of rocker arms matched to their respective valve and cylinder.
3. Inspect the end, or tip, of each exhaust valve stem where it makes contact with the respective rocker arm.
4. Determine if each exhaust valve is rotating within its respective valve guide. An exhaust valve that is rotating will have a “bulls eye” or circular wear pattern on the face of the valve stem tip. If the exhaust valve is not rotating, a straight mark-like pattern will be present across the face of the valve stem tip.
5. If there are exhaust valves that are not rotating, then proceed to the Valve Rotation section of this Repair Procedure.
6. If all exhaust valves are rotating, then this bulletin does not apply and further diagnosis is required. Install the engine rocker arms and valve cover. Refer to the appropriate vehicle service manual for detailed installation instructions.
Valve Rotation:
1. If one or more engine exhaust valves are not rotating, perform the valve rotation procedure to all six exhaust valves.
Note: It’s important that the Valve Rotation section of this repair procedure be performed.
2. Clean and mark the tip of each exhaust valve stem with a paint marker. The paint mark will be used later to assist with determining if the exhaust valve has been rotated 90°.
3. Bring the #1 cylinder piston to top dead center using the mark on the crankshaft front dampener/pulley. This step is important to prevent the possibility of the exhaust valve from falling completely into the cylinder.
4. Install the essential service tool valve spring compressor, MD-998772A, to the #1 cylinder exhaust valve spring.
Note: The following valve rotation procedure was developed with the use of valve spring compressor tool, MD-998772A. The MD-998772A compressor engages the entire perimeter of the valve spring retainer, unlike other make valve spring compressors.
5. Compress the #1 cylinder exhaust valve spring enough to gain access so that the exhaust valve can be rotated 90°. Rotate the exhaust valve 90°. Slowly remove the compression on the exhaust valve spring. Verify that the valve keeper is properly seated to the valve stem and valve spring retainer.
6. The 4.0L firing order is 1 - 5 - 3 - 6 - 2 - 4. Without rotating the engine crankshaft, repeat steps 3 through 5 to cylinder #6.
7. Rotate the engine crankshaft 1200 and repeat steps 3 through 5 to cylinders #5 and #2.
8. Rotate the engine crankshaft another 1200 and repeat steps 3 through 5 to cylinders #3 and #4.
9. Install all cylinder rocker arms (intake and exhausts) and retaining bridge. Make certain that the push rods are properly seated to their respective rocker arm and lifter. Tighten the respective cylinder bridge/rocker arm cap screws to 30 Nm (21 ft.-lbs.) when each cylinder piston is at top dead center (cylinder intake and exhaust valves are closed).
10. Install the engine cylinder head valve cover. Tighten the valve cover bolts to 10 Nm (85 in.-lbs.). Refer to the appropriate vehicle service manual for detailed assembly instructions.
Decarboning Combustion Chamber and Valves:
1. Start the vehicle’s engine and allow the engine to reach normal operating temperature.
2. Remove the air tube from the engine throttle body.
3. With the engine at idle, spray the entire contents of Mopar Combustion Chamber Cleaner, P/N 04318001AB, directly into the throttle body. As the cleaner is being ingested, allow the vehicle to “load up” with the cleaner to the point that the engine is almost stalling out. Maintain this condition until all of the cleaner is used/ingested.
4. Stop the engine once the entire can of cleaner has been ingested.
5. Install the air tube to the throttle body.
6. With the hood closed and the vehicle parked inside the garage, allow the vehicle engine to heat soak for two to three hours. This will ensure that the engine will maintain its temperature and will allow proper solvent penetration.
7. After engine soak, start the engine and drive the vehicle until the engine is has reached normal engine operating temperatures.
8. If the vehicle is equipped with an automatic transmission, place the gear selector into “L” (low). If the vehicle is equipped with a manual transmission, place the transmission into first gear.
9. In a safe vehicle operating location that will allow the vehicle to be driven safely and at the posted speed limit, accelerate the vehicle until the engine reaches 4,500 rpm.
10. Hold the engine speed at this rpm for 15 seconds.
11. Slow down and in a safe location pull to the side of the road. Allow the engine to idle for five seconds.
12. Repeat steps 9 through 11 five more times.
13. With the vehicle at operating temperature and using any available freeze-frame data recorded when the misfire DTC occurred, verify that the misfire condition has been corrected.
14. Erase any engine DTCs once the misfire condition has been corrected.
Technical service bulletin courtesy of Mitchell 1.
For additional information, visit www.mitchell1.com.
Tribal Jeep
Re: jeeps hate me
« Reply #6 on: January 22, 2008, 09:43:38 PM »
i had tthe same symptoms on a different vehicle, but after doing timing and checking wires and the cap it turned out to be a small head gasket leak.
Re: jeeps hate me
« Reply #7 on: January 22, 2008, 11:28:27 PM »
well i replaced the spark plugs tonight.  the old ones looked a little worn, but i don't think they were that bad, however, engine kicked over nicely, and it just felt like it was running better. took it for a spin and it didn't do the stalling. so i'll take her for a longer spin tomorrow, and we'll see
Re: jeeps hate me
« Reply #8 on: January 23, 2008, 10:48:41 PM »
well drove around some more tonight, and it did the same thing again. trouble maker i'm thinking that thing you posted might be probable. also, when we just rev her up i can smell it burning oil or something. pulled the plugs again to take a look, they look fine.  i thought the oil leak it has was the rear main seal, but i'm now thinkin its possibly a head gasket??????  so when i rev it up every once and a while, its ok. its just cruisin on straight aways that it does its thing........... so confused right now. debating just pullin the engine...... any other ideas?
Re: jeeps hate me
« Reply #9 on: January 23, 2008, 10:53:45 PM »
 ;D ;D ;D
Offline XJwrencher
  • Pavement Princess
Re: jeeps hate me
« Reply #10 on: January 23, 2008, 11:35:36 PM »
Id give it a fuel pressure test if the pumps on the way out it wont run right should be between 35-45 psi  just my 2cents.
94 XJ with tires and sausage to make it go off roading
xooma
Re: jeeps hate me
« Reply #11 on: January 24, 2008, 10:57:27 AM »
Had the same experience with a couple of vehicles and found out it was the EGR valve just unplugged the vacuum line and all seemed to work good. Just make sure you plug the vacuum line if this is the problem.
Just a thought worth the try.
Re: jeeps hate me
« Reply #12 on: January 24, 2008, 03:45:32 PM »
hmm, will try the wires tonight.  donno if the jeep has an EGR as its a 4.0L. anyone confirm? i'll check when i get home.  will also check for timing and compression
so if its the head gasket, that'd mean oils leaking into a cylinder somewhere then probably?
Offline dubbleJs
Re: jeeps hate me
« Reply #13 on: January 24, 2008, 04:05:39 PM »
Coolant will leak into your cylinders, does it blow smoke at all....specifically white smoke?
Re: jeeps hate me
« Reply #14 on: January 24, 2008, 06:08:20 PM »
Sometimes it will also push combustion gas into the AF. If you pull the rad cap you may see bubbles coming up while its running.
