Author Topic: Garvin tire carrier  (Read 4671 times)
Offline RACKMAN
Re: Garvin tire carrier
« Reply #15 on: January 27, 2008, 05:47:09 PM »
Tribal Jeep...wouldn't you be over the $1000.00 National quoted me after you have the carrier shipped here? If not, then what do you think you will be at cost wise if you go with Quadratech?
RACKMAN
Tribal Jeep
« Reply #16 on: January 27, 2008, 08:16:14 PM »
not 1000.
« Reply #17 on: January 27, 2008, 09:48:28 PM »
Shipping, duty, and brokerage would put you just over 1100 from quadratech.
899 converted = 946
shipping 100$ (minimum)
GST 52
brokerage 55
total 1153
Tribal Jeep
« Reply #18 on: January 27, 2008, 11:23:24 PM »
well then.  :-[
« Reply #19 on: January 28, 2008, 04:05:32 PM »
try to get it from National for $1000 to $900... Try to deal with them... I usually try to build a relation with a shop and you'll see good deals coming across
Offline cotaman
« Reply #20 on: January 28, 2008, 06:13:37 PM »
Swampsinger has so many parts on his Heep  from National that he should own shares in the company :P
Offline Rookie
« Reply #21 on: January 28, 2008, 11:05:48 PM »
You mean he doesn't :o ;D
TJ with some stuff
Offline BrokenAxle
    • Broken Axle home page
« Reply #22 on: January 29, 2008, 08:18:19 AM »
nope, but he did sell his soul to them for those prices...
Offline RACKMAN
« Reply #23 on: February 02, 2008, 10:23:26 AM »
Thanks for the info guys...those that have this carrier, do any of you have the jerrycan carriers? I'd like to know if I need the basket to mount them or if the can carriers are mounted on the frame of the swingout itself? Also, did the weight of this unit cause you too lose suspension height? Did you need to add a coil spacer to restore ride height? Thanks.
RACKMAN
Offline RACKMAN
« Reply #24 on: February 03, 2008, 10:27:23 AM »
Anybody?
RACKMAN
Offline Rookie
« Reply #25 on: February 03, 2008, 11:40:15 AM »
RACKMAN
I looked @ the garvin before I built mine
You don't need the rack to mount the jerry cans but if you have a hard top make sure you get the swing away passenger side can mount or you won't be able to open the hard top glass If I had bought the garvin I was going to add a grease fitting to the hinge and change the screw style latch to a cam lock style
But why spend a grand + than start cutting and changing it so I built from scratch
As for weight I find that it evened it out with the winch on the front
HTHs
Steve
TJ with some stuff
