Author Topic: Cat converter question  (Read 940 times)
Offline jeepjones
« on: February 01, 2008, 11:51:38 AM »
I was wondering if a '98 Tj will run ok if the cat is removed?
Re: Cat converter question
« Reply #1 on: February 01, 2008, 12:14:11 PM »
there have been a few topics on this posted, dunno where though you will have to use the search
Offline TJ54
« Reply #2 on: February 01, 2008, 06:40:50 PM »
My 97 4banger ran like crap without the cat,  I changed both the o2 sensors at the same time as I put in a new hi-flow Magna flow cat, My heep then ran way better.
So was it the new cat or the sensors?? I dunno.
If you look around you may find a good price on the magnaflow
« Reply #3 on: February 01, 2008, 08:38:57 PM »
It will run fine without the Cat but you must retain the O2 sensors. If there is an O2 sensor in the Cat then you need to put one into the pipe that replace it.
