Author Topic: aussie locker in a ZJ D35  (Read 1300 times)
« on: February 09, 2008, 07:58:58 PM »
don't want to spend to much on these axles, but i wanna be locked this summer...... so asides from welding her solid, can i use an EZlocker or an aussie in my d35, which has the tracloc in it right now? or do i need a new carrier?
thanks
John
Offline BrokenAxle
    • Broken Axle home page
Re: aussie locker in a ZJ D35
« Reply #1 on: February 10, 2008, 05:38:30 PM »
you will need and open carrier.  even if you wanted to weld it you'd need an open carrier too...
« Reply #2 on: February 10, 2008, 09:01:39 PM »
so might as well do a full case locker and gears then eh?
Offline BrokenAxle
« Reply #3 on: February 10, 2008, 09:34:10 PM »
go big or go home...
Offline cablesmurf
  • Relapsed Jeep Addict
« Reply #4 on: February 10, 2008, 10:28:37 PM »
Quote
One great advantage of the No-Slip is that it can be installed inside the Trac-Lok LSD carrier, as well as many other LSD carriers.
http://www.4x4wire.com/reviews/no-slip/
Offline BrokenAxle
« Reply #5 on: February 11, 2008, 08:19:07 AM »
i sit corrected...
Offline cablesmurf
« Reply #6 on: February 11, 2008, 08:41:39 AM »
Sorry Dave... :P
Offline BrokenAxle
« Reply #7 on: February 11, 2008, 05:27:19 PM »
no worries,  it's good to know there are other options out there!
