Author Topic: help  (Read 2309 times)
Offline XJHERO
  • Soberphobic
help
« on: September 06, 2005, 10:11:22 PM »
Hey I was wondering if anyone might be able to give me sum tips for my 91 xj 4.0 H.O.  Its runing like a bag of crap, bucking and back fireing thru the intake under load and sumtimes the idel surges. And no check engin light is coming on, A new tps did not help. This problem just had to start while i was down a trail in waiprous that sucked but it limped home. I also have an 87xj that does a samething and i changed just about everything from wireing harnsses to several computers, mapsensors tps, cranck sensor, knock sensor, fuel rail, injectors, fuel filter, injector harness,distributer,cap, spark plugs,and more. Is there sumthing any one could sugest?
thanx
DD
Get at me Wolf
Offline 4low
help
« Reply #1 on: September 07, 2005, 12:11:20 AM »
A leak in the intake somewhere after the throttle body?
start the engine and spray wd-40 onto all the gasket surfaces/intake tracts and see if the idle smooths out..........
BTL WGN
Offline XJHERO
  • Soberphobic
got it
« Reply #2 on: September 18, 2005, 02:59:39 PM »
I fixed my 91 xj, I checked the fuel pressure and it only had about 13 pounds of pressure. It turns out the rubber hose between the fule pump and sending unit inside the gas tank had come off most of the way and it was loosing pressure there. so all i had to do is tighten one hose clamp. The previous owner must of had a fule pump installed and one of the hose clamps was not tightened during installation. Aint it great when ya run into a cheep fix.
one down one two go
DD
Get at me Wolf
Offline 4low
help
« Reply #3 on: September 18, 2005, 10:57:38 PM »
Cool to hear!
never would have thought of that!
Sweet
BTL WGN
Offline redbull
Re: got it
« Reply #4 on: September 19, 2005, 02:11:47 PM »
Quote from: "87xjheep"
...I checked the fuel pressure and it only had about 13 pounds of pressure. ...
Whay do you use to check fuel pressure? I know there's a Shraeder valve on the fuel rail, but where whould I find the right gauge?
born2jeep
help
« Reply #5 on: September 19, 2005, 04:21:05 PM »
try cleaning the EGR... worked wonders on mine. :?
Offline XJHERO
  • Soberphobic
fule pressure guage
« Reply #6 on: September 24, 2005, 05:19:16 PM »
its called a fule pressure guage just shop arround there are lots of diffent makes, any where that sells tools ok maby not everywhere.
DD
Get at me Wolf
