Author Topic: Sandblasting  (Read 1989 times)
Offline LanceM
    • http://community.webshots.com/user/lancemacwilliam
Sandblasting
« on: February 14, 2008, 10:17:43 PM »
Anyone try out any of the sandblasters from princess auto? I know more than likly there crap but sometimes there stuff supriseingly works.
But if not wheres the place everyone takes they stuff to get blasted, and anyone have prices per bag/hour??
If it ain't broke, it ain't mine.
Re: Sandblasting
« Reply #1 on: February 14, 2008, 10:20:11 PM »
there was a post on this a while back, 6 months or so.  about the PA blasters and places around town to do it.  search should bring it up.
yjcanibul
Re: Sandblasting
« Reply #2 on: February 14, 2008, 10:26:27 PM »
consolidated compressor has drive up bays,  supply overalls/gloves etc, drive away no mess ...
Offline Gearhead
Re: Sandblasting
« Reply #3 on: February 14, 2008, 11:38:29 PM »
I use Consolidated too , they are just south of pick yer nose on Barlow , a few blocks and to the left , you can't miss the clouds of toxic dust  and deafaning noise.
Oh , yes , I've got a   one bagger   PA pressure pot sandblaster , it works pretty good . You need some CFM to run it properly , or lot's of time , while waiting for the compressor to catch up . Best used on smaller projects but a  good deal when they are on sale . Avoid the cheesy gravity or siphon feed units , waste of time those ones , about as effective as  filling your mouth with sand , then blowing it through a straw .
 ;D
Offline LanceM
Re: Sandblasting
« Reply #4 on: February 15, 2008, 08:12:32 AM »
Thanks guys, was hoping for something a little closer to the NE but do it yourself sounds cool. Still might try one of the PA guns first
Offline 01sahara
Re: Sandblasting
« Reply #5 on: February 15, 2008, 08:48:20 AM »
If its a big job go to consolidated. In one hour there last summer I blasted my entire steel utility trailer back to bare metal top and bottom.  It worked great, very powerfull machine.
Re: Sandblasting
« Reply #6 on: February 15, 2008, 02:17:55 PM »
just got the PA flyer for the Feb 19th Sale.  there's a 10 gallon pressured sandblaster $179.99 $112.22
Offline LanceM
Re: Sandblasting
« Reply #7 on: February 15, 2008, 05:46:41 PM »
Thanks for the heads up FiEND,  got lots of stuff big and small so this should be a little easyer on the wallet.
Offline cuzican
Re: Sandblasting
« Reply #8 on: February 15, 2008, 06:33:33 PM »
I have the large PA sand blast cabinet.  Leaks sand through the door and at the seams - I would suggest if anyone gets one of these to silicon all the seams during assembly. I modified it to use a shop vac air filter at the rear outlet. Works not too bad.
Offline barmanjay
Re: Sandblasting
« Reply #9 on: February 15, 2008, 10:55:46 PM »
I know a guy that does amazing work
bath then bead blast
absolutely amazing work
http://www.hotwheelz.ca/forum/index.php/topic,848.0.html
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline barmanjay
Re: Sandblasting
« Reply #10 on: February 16, 2008, 02:08:52 PM »
before and after
Jason Kim
Realtor
889-4747
www.jaykim.ca
Offline LanceM
Re: Sandblasting
« Reply #11 on: February 16, 2008, 09:20:32 PM »
Is this stuff all yours and if so whats abouts did it run ya??
Offline barmanjay
Re: Sandblasting
« Reply #12 on: February 16, 2008, 10:48:54 PM »
i have no idea what he charges
he did this for a couple friends on another site
By the sounds of it,.. he does this stuff on the side for pretty cheap
he's hot tanked a few engine blocks and etc for other friends aswell.
i would go over and send him a PM if you wanna know what he'd charge
Jason Kim
Realtor
889-4747
www.jaykim.ca
