Author Topic: 89 Cheep Cherokee Problems Backfiring  (Read 1676 times)
Orex
« on: February 24, 2008, 10:51:49 AM »
My Jeep will start and run, but as soon as I hit the gas, the engine backfires.  I have replaces the CPS and the TPS.  What do I need to do next?
Re: 89 Cheep Cherokee Problems Backfiring
« Reply #1 on: February 24, 2008, 11:52:05 AM »
Have you messed with the distributor lately? If so did it get put back in its proper position? Are all the plug wires going to the correct plugs(none mixed up), are the wires in good shape(not cross firing to each other?).
Any vacuum lines popped off?
Offline big black dodge
« Reply #2 on: February 24, 2008, 11:29:54 PM »
you check for exhuast leaks and/or cracked exhuast manifold?
81 CJ7 350, SM 465, Dana 300,  dual dana 44, 4" lift, soon 33" TSL
Orex
« Reply #3 on: February 25, 2008, 05:34:57 PM »
I don't believe so but I will check.  By the way, the plugs you mean  are the firing order for the spark plugs right?
Orex
« Reply #4 on: February 25, 2008, 05:37:28 PM »
Oh and is there any way I am supposed to adjust the CPS?
Offline rws
  • Stump Grinder
« Reply #5 on: February 26, 2008, 03:19:31 PM »
CPS is not normally adjustable.
Orex
« Reply #6 on: March 11, 2008, 06:13:23 PM »
None of that is the problem!!!   Anyone else have a suggestion?
« Reply #7 on: March 11, 2008, 07:16:15 PM »
Vaccum lines and/or timing ?
« Reply #8 on: March 11, 2008, 07:45:36 PM »
We need more info. Did it just start or happen after doing work on it? What all have you tried/replaced.
Offline NS-jeeper
« Reply #9 on: March 11, 2008, 08:19:14 PM »
Water in the gas?
yjcanibul
« Reply #10 on: March 11, 2008, 10:04:40 PM »
x2
is this a high mileage eng ,  is it gutless while on the gas and back firing ,  do you have a cat converter , did you have the timing chain off etc ...
« Reply #11 on: March 11, 2008, 10:14:41 PM »
Is the Jeep grey, lifted with 35" tires ?  ;D
Check and/or replace the following:
Part # 4762592 is circled in red
Part # 53004838 is circled in green
Part # 53004868 is circled in blue
« Last Edit: March 11, 2008, 10:22:09 PM by frenchy »
Orex
« Reply #12 on: April 06, 2008, 07:55:06 PM »
No, it is Blue and stock parts
unionjack
« Reply #13 on: April 07, 2008, 08:07:49 PM »
plugged catalytic converter? just athought
Offline BUKI
  • Project Fugly
« Reply #14 on: April 08, 2008, 11:05:22 PM »
good one unionjack.
let it run for a while and se if the cat is red hot.  seen that happen before.
