Author Topic: Detroit locker issue  (Read 950 times)
Offline XJwrencher
  • Pavement Princess
« on: March 04, 2008, 12:20:55 AM »
Hey just wondering if anybody has installed the detroit C-locker for the 8.25 just having an issue with the crosspin clearing the ring gear  ???
94 XJ with tires and sausage to make it go off roading
Offline BrokenAxle
    • Broken Axle home page
Re: Detroit locker issue
« Reply #1 on: March 04, 2008, 07:11:33 AM »
the ring gear gets thicker as they get numerically higher.  eventually you can't get the pin out.  shave the ring gear just enough to get the pin out.
Offline XJwrencher
  • Pavement Princess
« Reply #2 on: March 04, 2008, 05:44:06 PM »
I was kinda figurin that but just wanted to get some input,doent look like i have take to much off mabey a 16th. there 4.56's.Thx for the input.
Offline yyc_tbird_sc
« Reply #3 on: March 04, 2008, 10:02:24 PM »
The 8.8's are the same way...some people say to notch the cross pin, but that will only weaken it. Grind the gears with a dremel or a die grinder with a sanding roll until they pin slides in. You may also want to try rotating the crown gear on the locker as this may position the teeth in a better position and allow the cross pin to slide between teeth.
Just be sure to keep everything covered up really well and clean all the crap up after grinding...
Offline cuzican
« Reply #4 on: March 04, 2008, 10:08:05 PM »
x2 don't shave the pin.  Use plastic and duct tape to cover up everything except the tooth you are grinding.
