Author Topic: Clutch is sticky and squeaky on my '94 YJ!  (Read 863 times)
Offline Shearcon79
« on: March 25, 2008, 09:34:04 PM »
Anyone know if it is possible to lubricate the clutch on my YJ without having to do any major dismantling?  It is very sticky and noisy when changing gears. :-\
Green 94 4.0 YJ :
4.5" RE Extreme Duty
33x12.5 MTZ's on 15x8 Black Steelies
Tera-flex Super Short SYE
Drive Products CV Driveshaft
Swing-away Tire Carrier/Bumper/Hitch
Found D44's out of a Waggy...Just need to build them
Offline hps4evr
  • Administrator
Re: Clutch is sticky and squeaky on my '94 YJ!
« Reply #1 on: March 26, 2008, 06:03:11 PM »
ummmm, might wanna add some more info. when you say lubricate the clutch... i think of grease on the flywheel and clutch plate;)
YJ=Y’all Jealous
Offline Shearcon79
« Reply #2 on: March 26, 2008, 08:14:34 PM »
Ok.  I guess I'm thinking about the clutch cable.  The thing is is that when I am releasing my clutch it is very sticky and will not allow me to ease it off.  All of a sudden it lets go and in turn my Jeep jolts forward.  It is obviously worse in a lower gear when I am pulling away from a stopped position.
Green 94 4.0 YJ :
Offline jpthing
  • I like things with wheels.
« Reply #3 on: March 26, 2008, 09:20:07 PM »
I'm pretty sure your clutch is hydraulicly actuated, check the fluid level, otherwise it's probably time for a new clutch...how long have you had the jeep? has the clutch ever been done? do you drive through muddy water? squeaky usally means throwout/pilot bearings....does it squeak while you push it? while it's held in?
'97 TJ, 5" lift, 35's "Sprout"
'95 Xj, 4" lift, 33's Sold to the Bagman
'10 JK unlimited
"Whether you think you can or think you can't...you're right."
-Henry Ford
I'm finally over the Jeep bike debacle..
« Reply #4 on: March 27, 2008, 07:01:04 AM »
Your clutch is hydraulic, nothing to lubricate.  I would before start with checking the fluid level
Offline barmanjay
  • Wanna buy a trail? or Garage w/attached house?
« Reply #5 on: March 27, 2008, 10:21:44 AM »
The realtor that gets dirty
Dirty Old YJ , 4" spring lift and 33's  - Sold - *snif*
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
