Author Topic: Rollerized injected 401 into Blinkinlights Waggie. Yes there is a test.  (Read 1120 times)
Offline AMCcrazy
 OK so I mated Gregs tranny and motor and with a 2 hour fight with torque converter bolts(put in oversize bolts but converter was drilled 32nd of an inch off on two holes) I hoisted it high overhead and it began its journey back to life.
This is the test part.
What is wrong with this picture?
you have to look close
here is another angle
here it is in the bay I will put the tranny xmember on tommorrow and then wheel it back outside.
lots of friggin AMCs and Jeeps
Offline Rookie
2 wheel drive tranny
divorced transfer case??
TJ with some stuff
Offline AMCcrazy
you are absolutely right.
Offline Rookie
Do I win anything??
TJ with some stuff
Offline AMCcrazy
uh? I hadn't thought it that far through.
ARGRRLL.....(homer drool...)
