Author Topic: Off Road Trailer  (Read 1627 times)
Offline Waytec
  • not all there
Off Road Trailer
« on: April 08, 2008, 01:13:51 AM »
I am getting a trailer frame from a friend. It is a tent trailer out of the early 80's but the nothing is anygood except for the frame.
I want to build a trailer that I can take into the bush for trail projects and also use it as utility trailer.
Some of the plans are to put 33 or 35s on it for tiers. I was thinking 4 feet wide and 8 feet long So I can carry a standart 2x4. I was also thinking of running slider bars from the axles to the front and to the rear so it would slide up and over stuff.
If anyone has any ideas and pics of trailers they have built I would love to here them.
thanks
The obstacle is the path.
Offline Shearcon79
Re: Off Road Trailer
« Reply #1 on: April 11, 2008, 04:58:41 PM »
I haven't built one myself but a guy I met offroad a couple years ago had a tent trailer that he did some mods to.  His trailer had leaf springs so he converted them to the top side of the axle.  For the hitch he had a swiveling pintle hitch.  I was totally awesome the way it would maneuver over the terrain.
Here is a link to some different pintle hitches
http://www.thehollandgroupinc.com/Portal/Products/Couplers/PintleHooks/
Green 94 4.0 YJ :
4.5" RE Extreme Duty
Tera-flex Super Short SYE
Drive Products CV Driveshaft
Offline Fredduck
  • RIDE ON
« Reply #2 on: April 11, 2008, 06:23:32 PM »
Buy Cuzican's backhalf of his Jeep add a tube frame and a hitch.
Just trying to plug your jeep body Steve :)
Offline Waytec
  • not all there
« Reply #3 on: April 12, 2008, 12:40:43 AM »
Thanks for the suggestions. I am going to run a pental hitch for sure.
For length and width was going to have it so I can put a 4x8 sheet of plywood on the inside and close the end gate.
I was also going to have it so I can put a tarp over the top to make the box water tit. I have not figged this one out yet, so if there is any suggestions post them up.
« Reply #4 on: April 12, 2008, 07:24:21 AM »
Have you measured the trailer yet? I had an old tent trailer that I converted to use as a utility trailer. It had a 6X6 box. Too wide for most trails and the springs were pretty light.
Offline Fredduck
  • RIDE ON
« Reply #5 on: April 12, 2008, 09:05:50 AM »
Back half of a step-side pick up - box is 4X8 , you can take the fenders off  for tight trails, good strong frame
Use the same diff as you run in you unit, then if you have issues you would have a spare. Just a thought :)
Offline Waytec
  • not all there
« Reply #6 on: April 12, 2008, 09:57:40 PM »
I have not measured it yet. But I already know it is too wide as is I'm going to narrow it. I am not going to be any wider they my XJ.
« Reply #7 on: April 13, 2008, 08:12:24 AM »
Had a truck box trailer once, heavy SOB! Would not suggest getting one unless your Jeep has a Cummins!  :D
Offline Fredduck
  • RIDE ON
« Reply #8 on: April 13, 2008, 08:32:40 AM »
I agree ;) but if he has a tube frame already, a stepside truck box would tif the bill nicely. Most long box stepsides are 8 X 4 and the fender can be taken off for tight trails.
Offline rws
  • Stump Grinder
« Reply #9 on: April 13, 2008, 12:19:53 PM »
I converted an old tent trailer to a utility trailer and by the time I was done I had so much time and money into it I wish I would have never started on this project.  If I was to do it over I would go to PA and check out axle prices and just custom build from scratch.
