Author Topic: 87 XJ 4.0 bad idle and stalling  (Read 990 times)
Offline WagoneerXJ
  • Bagon Wagon!
« on: April 08, 2008, 03:45:07 PM »
So my XJ is runnin weird. 87 XJ Renix 4.0/Auto. When ya fire it up it runs fine for a couple minutes, then the idle bounces around, between 100 and 800. When it idles really low like that, sounds like I have a wild cam in it. Kinda like the timing is off, or it's missing.
 When I'm driving it, and pull up to a stop sign or to make a turn, if I don't put it in Neutral and keep my foot on the gas, it will stall. Other than that it runs fine above 1000 rpm, acceleration seems unaffected. Any ideas what the hell is goin on?
I cleaned and replaced the IAC, TPS and checked the plugs. No change :(
 I have a complete 89 XJ 4.0 to take parts from if I need them.
84 Mustang GT-Built 351W 5spd
Offline rws
  • Stump Grinder
Re: 87 XJ 4.0 bad idle and stalling
« Reply #1 on: April 09, 2008, 08:20:13 AM »
This really sounds like a TPS, if this is a high milage vehicle it proable needed replacing anyway.  Should be set with a DVOM and check the ground wire, sometimes a new one has to spliced in.
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #2 on: April 09, 2008, 11:30:03 AM »
I replaced the tps with a spare one I had. No change  :(
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #3 on: April 09, 2008, 06:38:06 PM »
Got it figured, was a vacuum line to the EGR
