Author Topic: Front brakes  (Read 1077 times)
Front brakes
« on: April 16, 2008, 11:53:55 PM »
Ok, so my brakes are now toast, grinding horribly.  How easy is it to install new ones and do I need rotors and pads or just new pads?
Re: Front brakes
« Reply #1 on: April 17, 2008, 07:08:02 AM »
Brakes are very simple and when yuo replace the pads you should either have the rotors turned or replace them and replacing is cheaper
-support vehicle
-remove tire
-unbolt the 2 caliper bolts on the inside of the caliper
-remove caliper (need 12 point 13 mm or 1/2" socket)
-remove pads and if needed remove rotor
-you will have to compress the piston in the caliper with a large clamp or something
-reverse the process
Re: Front brakes
« Reply #2 on: April 17, 2008, 08:21:06 AM »
last time i got my rotors turned was $14 for 2 of em.  autovalue on macleod.  not expensive.  be prepared to buy new ones though - maybe $30 each.  there isn't a lot thickness to turn em much anymore so age is a big factor.  if yours are grinding, chances are they can't be turned as they will have grooves in them.
i'd get a haynes or other repair manual, especially if you have drums in the back.
Re: Front brakes
« Reply #3 on: April 17, 2008, 11:15:11 AM »
WOW, I got seriously screwed the last time I had my rotors turned then  >:(
Re: Front brakes
« Reply #4 on: April 17, 2008, 02:58:48 PM »
I'm lazy and got a shop to do it for me.  Rotors had to be replaced, new pads, and rear brakes adjusted.
shibby
Re: Front brakes
« Reply #5 on: April 18, 2008, 01:31:55 PM »
had to do mine recentley - both front rotors were badly warped.
Rotors were rusted/seized onto the hubs pretty bad. Needed lots of penetrating oil and a hamer to get them off. New ones slid on like a glove.
