Author Topic: CB antenna  (Read 1668 times)
Giffer
CB antenna
« on: April 26, 2008, 11:03:59 PM »
hey, has anyone here used one of those cheap antennas from the source?? its almost cheap enough just to try, but if someone hrere has used one then might as well try here first.
Offline i_go_commando
Re: CB antenna
« Reply #1 on: April 27, 2008, 07:28:52 AM »
do forget places like truckstops. i know the fling j at barlow and deerfoot has a large selection of antenas. Also i know walmart also carrys some cb equipment
keith
oh and if there anything like the old radio shack mag mounts ive used them for years without problems. the magnet can be unbolted, and then you can just bolt it to your antenna mount. i found the weekspot was the cable as i alsway seem to break the cable right at the end into the antena. but cable is cheep and replacable
« Last Edit: April 27, 2008, 07:31:12 AM by i_go_commando »
Offline scott/kerri
Re: CB antenna
« Reply #2 on: April 29, 2008, 08:42:52 PM »
the road king at pegain trail and deerfoot has a cb shop. they have lots of goodies, radios, under hood mounts and a whole lot more.
Scott has the 04 tj...nickname itty bitty
Kerri has the 09 jk , 4 inch lift
Offline calltrex
Re: CB antenna
« Reply #3 on: April 29, 2008, 09:39:10 PM »
i bought all my stuff from the road king.
« Last Edit: May 01, 2008, 08:19:50 AM by calltrex »
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Re: CB antenna
« Reply #4 on: April 30, 2008, 04:36:41 PM »
You are better off having a cheap radio and good antenna than the other way around. Your antenna has more to do with the performance of your CB than the radio does.
Offline dubbleJs
Re: CB antenna
« Reply #5 on: June 02, 2008, 04:32:01 PM »
Just gonna bump this thread...
I got my hands on a Cobra 19 Ultra and am looking for an antenna. I went to Flying J's and they have a 4ft antenna w/ mounting bracket for $50....Whats the best length to get and what kind of prices have you guys found around the city?
Re: CB antenna
« Reply #6 on: June 02, 2008, 04:51:46 PM »
comtek @ road king
get the 4' wilson flex $40
get the 18' braided coax with a screw on end $30 or so
he has a variety of mounting brackets with studs $10-$25 or so.
this is where you do not want to cheap out.
Offline dubbleJs
Re: CB antenna
« Reply #7 on: June 03, 2008, 05:02:22 PM »
Ok thanks, so Ill be looking about about $70-80 for a good one?
The 4' one at FJ's comes w/ 18' of cable and a mounting bracket for $49...dont think it was a Wilson though..not sure. Im on a budget and appreciate your suggestions!
  8)
Offline cuzican
Re: CB antenna
« Reply #8 on: June 03, 2008, 07:07:01 PM »
Don't know if it was a one off but Princess Auto in Lethbridge had a 48" whip with bracket and cable for $12.95
I didn't buy it cause I thought it was too expensive - I've been buying CB stuff at garage sales and swap meets for years for next to nothing - just gotta keep looking. Three weeks ago I got a box with a next to new CB, two antennas, several cables, brackets, external speakers and other stuff for $5.
Re: CB antenna
« Reply #9 on: June 06, 2008, 09:16:43 PM »
Stopped it at Road King today. Picked up a 5ft Wilson Antenna, 18ft cable, and stainless steel mount. Al in all it was $120 but everything was top end.
Re: CB antenna
« Reply #10 on: June 06, 2008, 09:23:47 PM »
Clay, where does it mount up on the ZJ?  I kinda want mine mounted on the rear, out of the way on the trail.
Re: CB antenna
« Reply #11 on: June 07, 2008, 09:01:38 AM »
I demand the best possible performace from my CB. So there is only one choice. The center of the roof.  :o
I never use the sunglass or garage door opener compartment in the overhead console so one of those will be gutted and then the cable will snake up the a pillar, across the front top of the windsheild tucked into the liner and then into the overhead console. The hole will be drilled so that the base of it ends up inside the overhead console.
I did this on my XJ and sealed the base with a bit of silicone and never had an issue with leaking.
