Author Topic: Voiding TC drop in 3" lift  (Read 748 times)
HeadHunter
« on: April 29, 2008, 03:46:29 PM »
I dont want to lost the clearance that you get from a 3" lift by dropping the TC down. That is stupid. I know Rubi's dont have to do this for up to a 4" lift (due to their superior rear D shaft), but can I get away with not doing it in my sahara with only a 3" lift? Or is it mandatory to drop the TC.
I would rather go and purchase a longer CV drive shaft and possibly a SYE even for the 3" lift than drop the TC. Get one to fit up to a 6" lift for a future upgraded lift. Maybe even get a tummy tucker kit as well.
It would be the cat's meow if I could avoid the TC drop without upgrading the drivetrain.
What do you guys think.
Re: Voiding TC drop in 3" lift
« Reply #1 on: April 29, 2008, 04:08:59 PM »
I would install the lift and see how it runs first without the t-case drop.  If you do get vibs, you can install adjustable upper control arms to rotate the diff or install a BL with a motor mount lift or go the SYE route
« Reply #2 on: April 29, 2008, 07:40:31 PM »
I went with a Slip Yoke Eliminator on my XJ... I know it's not the the same set up at all but it worked awesome for me.
I think it should work good for you with a 3" lift and a drive sharf with a CV joint.
It's definately not cheap though....
check this out.... it might be good for you...
http://forum.calgaryjeep.com/index.php?topic=8767.0
« Last Edit: April 29, 2008, 07:45:33 PM by SwampSinger »
