Author Topic: squealing from front of motor.  (Read 1005 times)
mudpaw
« on: May 03, 2008, 01:55:28 PM »
hey all! I drive an 88 xj with a 4 litre, I have air conditioning....(never used it) I am having a hard time figuring out what is squealing..  I  know it is from the front... (belt or pulleys)  brand new altinator.( I thought that at first because the voltage reg. went) the noise is not always there,it happens once a week or so, it gets louder when I accelerate, (or rev) then sometimes just goes away. I read other posts about squealing until it is warmed up.. I don't  think that is the case.. the noise is hella loud and sounds like a belt squeal only LOUDER.  (i still think bearing.) I am planning on pulling out an A/C eliminator from pick and pull tommorow and hoofing the A/C (does anyone want it? it may still work I havent tried)
my power stearing fluid looks really dark (like coffee or cola) I think I am gonna grab a P/S  pump as well.. I have never changed one.. do I have to bleed it???
my hopes are that is A/C or P/S  maybe the idler pulleys?  I hope it is NOT the water pump or a motor bearing .  any ideas or help would be appriciated, like what bearings go most often??
thanks
mudpaw!
Dragonmaster
Re: squealing from front of motor.
« Reply #1 on: May 04, 2008, 01:28:48 PM »
Have you already replaced the belt?  If so it's probably the idler pulleys.  They go bad often.
mudpaw
« Reply #2 on: May 04, 2008, 05:41:55 PM »
thanks... i pulled out a new looking one from PnP today (idler pulley).. I also got an A/C eliminator I am installing right now. I will let you know.  thanks again for the help!  :)
I also got a brand new looking starter... (my starter is fine) lucky find I guess.
mudpaw!
Oh the belt is brand new..(edit)
« Last Edit: May 04, 2008, 05:43:50 PM by mudpaw »
Offline red95jeepyj
  • my jeep
« Reply #3 on: May 04, 2008, 09:20:24 PM »
or it could be your a/c bearings if you havn;t used it in awhile correct me if i am wrong
mudpaw
« Reply #4 on: May 05, 2008, 10:44:24 AM »
well A/C is out... the noise is even louder.... wow. I just tookk off my belt,  no noise (glad its not the motor)  I am gunna try it with no fan.....maybe fan clutch?...
can I press out the bearing in my idler pulley and put a new one in??
once again thanks for all the help... I am running in circles
« Reply #5 on: May 05, 2008, 11:03:54 AM »
If it is the PS pump the squeel will get louder as you makes turns.  I recently had my idler pulley go and there was tons of play in the bearing.  Does the newer idler pulley spin freely?
As for the fan clutch it should spin a little bit if the bearing is good and hardly spin if it is done for.  Also if you have a long screwdriver or stethescope, listen to the bearings with the engine running, just watch out for the fan
mudpaw
« Reply #6 on: May 06, 2008, 10:53:02 AM »
fixed...running great.. I pressed.....(pounded) new bearings int my idler pulley and A/C eliminator pulley.  I have more power and it runs quieter.  I got the bearings from bowness auto parts for $4.61 each.  I am wondering if my belt tension wasn't tight enough as well. I thought it was but now it feels tighter.
thanks again everyone.. see you on the trails.
