Author Topic: oil spits out of carb  (Read 798 times)
Offline Matt4x4
« on: May 06, 2008, 12:40:32 AM »
I have this vehicle its been sitting for a good year. I drive it every now and then around the block. I see oil in the air cleaner tray, what does that mean?
Leaks oil from the bottom as well, I have not taken a closer look at it.
Offline rws
  • Stump Grinder
Re: oil spits out of carb
« Reply #1 on: May 06, 2008, 08:29:41 AM »
What type of motor??
« Reply #2 on: May 08, 2008, 08:34:28 PM »
if you have oil on the air filter it is probably a plugged pcv. clean out the pcv system.
Offline Matt4x4
« Reply #3 on: May 12, 2008, 07:56:50 PM »
There is no air filter in the thing. The engine is a 25 year old carburated  dodge 360. I will check the PVC valve tonight, I need to put more oil in the thing to see if the lack of power is due to that, plus when I was putting it on the uhaul trailer it seemed to smoke a bit, needless to say the truck was to wide and long for the uhaul trailer anyway, and they didn't charge me for the rental. My friend got the boot out of his house that he rents, I was planning to take it there to work on it, I now have to look for another place to work on it for a couple weeks. I might take the weekend and just rent out a bay, couple hundred bucks. I'd rather find a garage or beside the garage where I won't be rushed and miss something.
« Last Edit: May 12, 2008, 08:01:32 PM by Matt4x4 »
