Author Topic: What could cause clutch chatter  (Read 782 times)
shibby
« on: May 27, 2008, 10:21:50 AM »
Every once in a while I get a bit of clutch chatter (jerky take offs) when taking off in first gear. Happens more often when it's warmer out. If I let the clutch slip a bit more it goes away. There is no slipage in any other gear, no noise to speak of, can't find any oil leaks, and hasn't been offroad in quite a long time.
Any ideas?
Mr-B
Re: What could cause clutch chatter
« Reply #1 on: May 27, 2008, 08:18:15 PM »
have ya bled the slave cylinder? Could be air in the line.  an air bubble will compress at different rates with different temp. Just a hunch tho...
Good Luck
Dragonmaster
« Reply #2 on: May 28, 2008, 05:37:33 PM »
Warped clutch disk, flywheel or pressure plate.  Could be a combination of all of the above or just one of the above.  I've got the same thing, but only when warm?
