Author Topic: Head All replaced  (Read 816 times)
Jeepgirl
Head All replaced
« on: May 27, 2008, 08:21:07 PM »
Will a head from a 94xj 40 work on a 92 yj 4.0 HO???  Can someone please let me know Thanks  Very Much  :-* :-* :-*
« Last Edit: June 16, 2008, 01:28:18 AM by Jeepgirl »
Mr-B
Re: Head
« Reply #1 on: May 27, 2008, 08:40:28 PM »
yuppers it should, check the head casting number, probably be 0630, the number will be on the top of the head, next to the valve cover, should be visible without taking stuff apart...
« Last Edit: May 27, 2008, 08:42:16 PM by Mr-B »
yjcanibul
Re: Head
« Reply #2 on: May 27, 2008, 10:52:32 PM »
91-95 4L should be casting #7120 (HO)  which covers both your jeep and donar so as Mr.B said check  midway along drivers side where valve cover meets block ... its clearly visible in good light ,  the following article suggests there are benefits/less issues sticking with your current head design ... if it is a #7120 you'll want to stick with it ...
http://www.jeepsunlimited.com/forums/showthread.php?t=839075
I believe 96 upto 98 4L used #0630 and then changed up again for 99 onward ...
Jeepgirl
Re: Head
« Reply #3 on: May 28, 2008, 12:01:53 AM »
Thank you for the help this is new to me.
Cheers :)
Mr-B
Re: Head
« Reply #4 on: May 28, 2008, 08:49:41 PM »
I think your right on the years yjcanibul...my mistake, way too much on the brain with the stroaker project ;D
