Author Topic: Coil Spring Compressors  (Read 1226 times)
Offline BEZZ
« on: June 06, 2008, 12:21:10 PM »
Hey Guys, So I've owned the Jeep for three weeks now and I'm half-way through a 3.5" Budget boost. I am having trouble getting the rear springs in though. Do I really need to buy a set of spring compressors? Tip and Tricks is what I am looking for or some one that has a set I could rent for the weekend for a six-pack. Gimme some directions here, I'm tired of driving the wife's Accord! Thanks in advance
Buy some safety glasses.
You can jackoff with a fake hand but you cant see out of a glass eye.
Offline fug
  • Airdrie Pick n Pull
Re: Coil Spring Compressors
« Reply #1 on: June 06, 2008, 02:52:01 PM »
Rear springs usually come out if you disconnect the shocks, sway bar and just let the axle hang (make sure you support the frame with some decent jackstands).   You may have to disconnect the track bar too (or lift one side of the axle forcing the other side down)
Fug
TJ Rubicon
Offline BEZZ
« Reply #2 on: June 06, 2008, 02:59:43 PM »
Oh I know the stock springs are out, its just getting the lifted springs in!
Offline Joel
  • Super Uber Web Wheeler
« Reply #3 on: June 06, 2008, 03:04:24 PM »
You can have another person push down on the axle while the other slide the springs.
or
I have a spring compressor you can borrow, i'm in the NW.
Offline calltrex
« Reply #4 on: June 06, 2008, 03:36:07 PM »
Only $10 at PA
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Offline BEZZ
« Reply #5 on: June 06, 2008, 03:58:43 PM »
Joel where in the NW are you? Is it a decent quality spring compressor you have or should I just get the $10 PA one...just worried about it blowing up in my face. :P
Offline Joel
« Reply #6 on: June 06, 2008, 04:20:12 PM »
I don't know if it's any better then the PA model, I bought it from Auto Value a while back.  Come to think of it you could probably borrow one from Parts Source.
I'm in Scenic Acres, across from Crowfoot (Crowchild & Nosehill Dr).
Offline calltrex
« Reply #7 on: June 06, 2008, 05:05:57 PM »
i used the PA one a few times and will use it more im sure.
its beefy enough. im not worried about it
........___________
.../""""/........J
HeadHunter
« Reply #8 on: June 06, 2008, 06:14:44 PM »
I just did mine last week end, had trouble getting the damn things in. I ended up using my breaker bar to pry the springs in. A flat crow bar would have worked a lot better.
