Author Topic: Partial lock-up  (Read 1221 times)
peter060
Partial lock-up
« on: June 12, 2008, 08:36:15 PM »
I have a 87 Cherokee, Just got it on the road, I'm having a problem of the front almost locks up when in 4WD and going in reverse. I know the front drivers U-joint needs replacing but it's not that bad as to cause a lockup.... Any hints ????
Re: Partial lock-up
« Reply #1 on: June 12, 2008, 10:28:49 PM »
what exactly is locking up?
peter060
Re: Partial lock-up
« Reply #2 on: June 25, 2008, 08:27:17 PM »
Well it  seems that the front diff  partially  jams , it seems to happen morewhen turning the wheels to the right, almost like the brakes are engaging , it drags
Offline barmanjay
Re: Partial lock-up
« Reply #3 on: June 25, 2008, 08:38:42 PM »
pull the diff cover and check?
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Re: Partial lock-up
« Reply #4 on: June 27, 2008, 05:54:45 PM »
how bad is that u-joint? it could bind things up.
Re: Partial lock-up
« Reply #5 on: June 27, 2008, 11:39:43 PM »
Just curious.... where do you test it also.. on the pavement?  You Heep on 4WD will never turn properly on the pavement...I'm sure you know that... just checking  ;)
Change your u-joints (do NOT buy the cheap u-joints... get Spicers.... trust me) and check your wheel bearings...
