Author Topic: swamped jeep, need help  (Read 1219 times)
mudpaw
« on: July 01, 2008, 06:47:51 PM »
hey all..well I went climbing in the ghost valley on  sunday afternoon when I went in.. the river crossing was fairly deep and fast..........when I came out, it was way worse. the river carried my jeep down stream.   I turned off the motor (so it didn't hydrolock) the water was almost to the roof rack, way over the steering wheel.. I swam out through the window.  :D   so I got pulled out almost right away (what a fight to get the strap on my tow hook...  I think I may have busted my hand)  . I have pulled the plugs (put oil down the cylinders) pulled the distributor (dried it)  I have tried lots of stuff... but no spark!    I can smell gas when I turn it over. and the motor sounds OK. (I also drained the water out of the motor)  I plan on changing all of my fluids.  why no spark??? I am at a loss right now... how do I check the coil ... I am getting power to it.
thanks everyone for your help
Andrew
Offline Gearhead
Re: swamped jeep, need help
« Reply #1 on: July 01, 2008, 07:05:09 PM »
The ECM may need to dry out for a few days as would the power distribution box.
mudpaw
« Reply #2 on: July 05, 2008, 12:17:19 PM »
OK .. so I now get intermittent spark when i turn the ignition on and off...but not when cranking it over..any help?...this is my daily driver.
« Reply #3 on: July 05, 2008, 05:44:11 PM »
check all your sensors. crank sensor can act up. i dont know what kind of jeep you have. but check the conections as well. they could have crap in them.
good luck
Offline jpthing
  • I like things with wheels.
« Reply #4 on: July 05, 2008, 09:30:43 PM »
cps, tps, spray out plugs with conntact cleaner etc...
'10 JK unlimited
-Henry Ford
Offline rws
  • Stump Grinder
« Reply #5 on: July 06, 2008, 07:51:39 AM »
Water can cause a multitude of electrical problems.  I would suggest you pick up a Haynes manual at Crappy Tire and read the part about testing the coil,  the description is very complete. I would also clean every sensor connector with contact cleaner  and put a dab of dielectric grease on it before putting it back together.
Water over the gas cap could mean a bit leaked into your fuel tank.
mudpaw
« Reply #6 on: July 06, 2008, 01:48:51 PM »
THANK YOU GUYS!!!  my jeep is an 88 cherokee 4 litre.  good idea with the greese.
