Author Topic: Track Bar issue  (Read 933 times)
Rubber Boots
Track Bar issue
« on: July 01, 2008, 08:38:14 PM »
Sigh, You would think from all the post that my Jeep is falling apart.  She isn't but there you know how it goes.  always more than one thing comes up at a time.  I have known for a while that my track bar was having troubles with the bushing on the body end.  I also know that I can't just replace the bushing on a stock track bar.  I know I can get a replacement bar that allows replacement of the bushing but I was hoping there might be a cheaper way to modify the factory one to the same end.  Any Ideas?
Gavin
Oh and how do I remove the track bar?  I was able to remove the castle nut from the body mount, but couldn't get the bolt to drop out.
« Last Edit: July 01, 2008, 08:41:35 PM by Rubber Boots »
Offline Waytec
  • not all there
Re: Track Bar issue
« Reply #1 on: July 01, 2008, 09:42:39 PM »
I don’t know if you can change the factory boot. To get it out you will need a pickle fork. CT, PA, House of tools all sell them.
The obstacle is the path.
Re: Track Bar issue
« Reply #2 on: July 02, 2008, 05:11:01 PM »
Wack the frame bracket with the round end of a big heavy ball peen hammer to get the taper on the TRE to release.  Just replace the whole thing if the axle end bushing is bad then most likely the TRE is shot as well.
Good time to upgrade to a aftermarket adjustable unit.
Offline jpthing
  • I like things with wheels.
Re: Track Bar issue
« Reply #3 on: July 05, 2008, 09:33:01 PM »
or go to pyp and grab one
'10 JK unlimited
-Henry Ford
