Author Topic: noise when starting off  (Read 1352 times)
Offline newfie
  • newbie and loven it
« on: July 06, 2008, 10:05:06 PM »
hey gang
new here and new too jeeping
my jeep makes this weird noise when i start off from a standing start
it sounds like the clutch or break pedal is jumping or chattering
newfies are everywhere
Re: noise when starting off
« Reply #1 on: July 06, 2008, 10:19:28 PM »
What Jeep, year, engine, trans do you have.  Welcome to the Jeep community.
Offline newfie
« Reply #2 on: July 06, 2008, 10:59:43 PM »
2000 tj
4.0l
5 speed manual
« Reply #3 on: July 06, 2008, 11:00:31 PM »
can you feel anything in the clutch/brake pedals?
Offline newfie
« Reply #4 on: July 07, 2008, 09:39:15 AM »
it  kinda feels like they might be jumping/chattering
Offline familyofjeeps
« Reply #5 on: July 18, 2008, 05:09:08 PM »
hey I just fix the same problem with my Jeep I replaced the clutch about a year ago and the samething started happing to me, my trany was falling away from my engine I just tightened the bolts and she was good to go after that I would suggest lock tight if the back of your motor is oily
hope this is some help
Family of Jeeps
what's around the next corner?
« Reply #6 on: October 01, 2008, 03:16:46 AM »
guess what, the heep is doing it again the trany is falling away from ym engine and I have the tuffest locktight on and it's still doing it and the clutch is leaking again what can I do to stop this is thier a stronger slave I can get to keep up with the abuse ? and what can I do about the trany falling off ?!?!?
 :Dthanks guys
Offline RckyMtnTJ
    • http://www3.telus.net/lck
« Reply #7 on: October 01, 2008, 10:38:42 AM »
Could also be the ball centering kit on your front driveshaft.  It is likely this if you are getting a rotational squeak that is speed related from about 10-50 km/hr.  After that the road noises take over.  If you suspect this too be your problem, try taking off the diff end of the driveshaft and tie it up really good and go for a drive and see if this fixes your problem.  DO NOT PUT IT IN 4WD WITH THE DRIVESHAFT OFF.
HTH,
Jeff
98 TJ 4" lift + goodies
