Author Topic: Easy Oil/Diff fluid change....  (Read 2397 times)
shibby
« on: July 21, 2008, 01:49:56 PM »
Well I decided to try out an idea I got after seeing a cool tool over at princess auto. I'm sure it's not a new idea as I've found a few devices for sale that are based on the same principle, but are more expensive. I got tired of spending a few hours just to change the diff fluids in my jeep, and after seeing a neat little Drill Pump over at princess auto, I figured why not try just sucking it out through the fill hole. Now I know that it's always good to take the cover off to inspect the gears, but if everything is running ok, and you just want to change your gear oil cause you might have gotten a bit of water in it. Then why not save yourself some time.
Parts wise it's pretty cheap.
Powerfist Drill pump - $9 - Princess auto
2 Hose-to-3/8 barbed adapters $5 each at home depot (required as the bits of hose supplied are not air tight at all)
Few feet of 5/16 ID clear hose - stretches onto the 3/8" barbed adapter to make a nice tight fit.
Before connecting it all up, make sure to open up the face of the pump and put a bit of oil in it to lube it up real nice. Otherwise you may burn up the drill pump before the fluid reaches it, another $9 later I learned my lesson. Once it's all connected, stick the "in" side hose into your diff, "out" side gets pointed into what ever container you want to catch your oil in, then start up the drill. Takes a few seconds for the pump to prime, but once the fluid hits the pump the flow rate is quite impressive, and don't need to run the drill hard at all... a nice low rpm is all that's needed. Will Drain the Diff in under a minute. The nice thing about this setup is you can use the same pump to refill your diffs, t-case, transmission... etc. Managed to do both diffs, t-case, and transmission fluid in about an hour and half... including the time to clean up the garage enough to get the jeep in, and assemble the pump LOL.
Offline fug
  • Airdrie Pick n Pull
Re: Easy Oil/Diff fluid change....
« Reply #1 on: July 21, 2008, 02:00:56 PM »
Nice!  Maybe I can avoid the piles of floor-dri in my garage the next time I change my diff fluid.  I guess I'll have to make stop on my way home from work tonight.
Fug
TJ Rubicon
Offline XJHERO
  • Soberphobic
« Reply #2 on: July 21, 2008, 02:14:12 PM »
Looks like a nice cheep way to get gas ;)
DD
Get at me Wolf
Offline fug
« Reply #3 on: July 21, 2008, 02:34:52 PM »
If you feel brave enough to run an electric drill that close to a $9 pump!  I'll stay a few feet back while you do.
Fug
TJ Rubicon
RUBI
Easy Plug Access !!!
« Reply #4 on: July 21, 2008, 03:17:37 PM »
Here's an easier way to get to those plugs !! :o ::)
« Last Edit: July 21, 2008, 03:30:59 PM by RUBI »
shibby
« Reply #5 on: July 21, 2008, 03:42:25 PM »
Well they also have a $19 drill pump made of Metal as apposed to plastic.
Plastic one says 200 GPM at 2000 RPM.
Metal one is over 600 GPM.
Still aint gonna pump gasoline with it though... I like my eybrows just how they are. ;D
Offline i_go_commando
« Reply #6 on: July 21, 2008, 04:46:02 PM »
use an air powered drill and a portable air tank...
yjcanibul
« Reply #7 on: July 21, 2008, 05:57:38 PM »
great idea!
I've been using a manual 'ulube it' handheld suction pump cylinder, 3 draws empties the D30, about 20minutes an axle incl fill and silicone the plug ...
Offline calltrex
« Reply #8 on: July 21, 2008, 06:59:27 PM »
You wont get all the oil out by sucking it but better then nothing..
If you got a rubicon theres already a drain plug at the bottom of the diff..
another solution is to weld a drain plug in the bottom of the diff cover the next time u take it off...
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Offline XJHERO
  • Soberphobic
« Reply #9 on: July 21, 2008, 11:53:49 PM »
Quote
:-X
DD
Get at me Wolf
« Reply #10 on: July 22, 2008, 01:53:58 AM »
lol looks like ace could become really cheap for me (in fuel costs that is)
