Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
oil presser gauge
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: oil presser gauge (Read 1159 times)
scott/kerri
Budget Lift
oil presser gauge
on:
July 22, 2008, 07:14:56 PM »
ever since i made that wave my oil presser gauge is fubared. i just chanced the oil presser sending switch that didnt help. i did notic when i bring the rpm,s up to 800 every thing goes back to normal. any ancers???
Logged
Scott has the 04 tj...nickname itty bitty
Kerri has the 09 jk , 4 inch lift
Tinkerer
UberWheeler
Re: oil presser gauge
Reply #1 on:
July 22, 2008, 09:42:42 PM »
Is it only the oil gauge that's weird at idle?
Logged
2004 TJ Rubicon 2.5" Cage Puck Lift
LT285/75R15 Trxus MT's
ARB Bullbar and Warn XD9000i winch
Garvin Wilderness Swingaway Rack
Cobra 75WXST CB, Yaesu FT8900 Ham
VE6PDB - usually on VE6RYC
scott/kerri
Budget Lift
Reply #2 on:
July 23, 2008, 06:23:08 AM »
Yes.....just did an oil change so know there is oil in it....onlyhappens after it has warmed upwhen first start the engine it is fine..then after it is warms it decides while idling to drop to "L"
Logged
Jeepgirl
Guest
Reply #3 on:
July 23, 2008, 08:24:26 PM »
Had the same problem with my YJ. Changed the oil pump and found out that the rear bearing is spun. Starts with good oil pressure but once it warms up the oil pressure is almost at zero. Good luck with yours mine cost me an engine. :'(
Logged
frenchy
Talks waaay too much!
Reply #4 on:
July 23, 2008, 09:48:20 PM »
Sounds like you got water in where there shouldn't be any.
I've got a spare engine with no oil pressure, caused by main bearings being shot.
If you don't drive it much, might be able to save it, but I wouldn't plan any road trips.
Logged
Jeep
With stuff
scott/kerri
Budget Lift
Reply #5 on:
July 27, 2008, 07:43:40 PM »
i have got it fixed the presure spring in the oil pump was sloppy so i installed a nice little flat washer . runs like new
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
oil presser gauge
