Author Topic: Rear Main Oil Seal  (Read 1323 times)
Offline 89YJGUY
Rear Main Oil Seal
« on: October 02, 2005, 04:29:11 PM »
Tonight I plan to change the rear main oil seal in my 89 YJ with the 4.2.
I forgot my tech book at work and was wondering if anyone here has the torque specs for:
     Oil pan bolts
     Oil pump bolts
     Crankshaft bearing caps
Thanks in advance.
Offline RckyMtnTJ
    • http://www3.telus.net/lck
Rear Main Oil Seal
« Reply #1 on: October 02, 2005, 05:14:27 PM »
In the FSM for my 98 TJ, it list the torques the same for the 2.5L and the 4.0L.  I am told that the 4.2 and 4.0 are essentially the same motor.  Here they are:
Oil Pan Bolts: 1/4 - 20 bolts 84 in. lbs.
                   5/16 - 18 bolts 132 in. lbs.
                   Drain Plug 25 ft. lbs.
Oil Pump Bolts: Short Attaching Bolts 204 in. lbs.
                      Long Attaching Bolts 204 in. lbs.
                      Cover Bolts 70 in.lbs
Main Bearing Caps:  Bolts 80 ft. lbs
HTH,
98 TJ 4" lift + goodies
