Author Topic: Difference between tcase  (Read 914 times)
stoggy97tj
« on: August 01, 2008, 08:04:14 PM »
Can anyone tell me the difference between a np231 tcase and a np242?
yjcanibul
Re: Difference between tcase
« Reply #1 on: August 01, 2008, 08:19:39 PM »
231 is known as 'command trac' , its been in wranglers for over 20 yrs, its a 'part time' transfer case so its only to be engaged in 4high/4low when wheel slippage will happen ( off road or snow/ice roads ) - it has lots of aftermarket support and is pretty dependable ... it also appears in some other vehicles ...
242 has been around for a long time as well and is known as 'select trac',  I had one in my '95 cherokee and my liberty has it,  its a 'full time' transfer case - it has the 4high/4low like the 231 that requires wheel slippage but it also has an extra 'full time' selection available on the gear shift ,  in this mode you can drive on all road surfaces (ice/snow/nice and dry) and not have to worry about it other than gas mileage will suffer - it handles the slippage it requires internally/automatically ... it doesnt have as much aftermarket support - as far as I know it too is pretty dependable ...
edit:  the 242 never came in a wrangler stock ...
« Last Edit: August 01, 2008, 08:33:49 PM by yjcanibul »
Offline Elsifer
« Reply #2 on: August 01, 2008, 08:20:39 PM »
Other than the round nameplate that is rivited to the rear of the tcase.
242 has a slip yoke eliminator in the rear, and is shorter.
Plus the housing might be aluminium.
But then again, I could very well be completely wrong.
Best bet, wash it. And look for some sort of nameplate on it.
VA6CPL
Jeepless....
Trouble Maker
« Reply #3 on: August 03, 2008, 02:37:27 AM »
You're thinking of the 241 rock trac used in the rubis with the 4:1 low range.
stoggy97tj
« Reply #4 on: August 04, 2008, 10:31:21 AM »
Thats a better answer than i was expecting anyways, thanks for the info.  I was just noticing a heck of alot of 242s available (in cherokees) but none for wranglers so i didnt bother getting one.
Thank you for the tips anyways, ill keep searching
