Author Topic: Gas mileage  (Read 3967 times)
Katt
Gas mileage
« on: August 12, 2008, 01:58:40 PM »
I recently purchased an '03 TJ, and I'm unsure about the 5th gear. I can't use it going uphill (unless I want to slow down to 75 or so) and I'm not sure how this is affecting my gas cunsumption.
Any comments would be much appreciated.
Re: Gas mileage
« Reply #1 on: August 12, 2008, 02:51:25 PM »
4 banger or 6 cyl?  Tire size and gearing?
Katt
Re: Gas mileage
« Reply #2 on: September 23, 2008, 02:11:48 PM »
Holy hell, that took me awhile to reply. It's the 4.o with stock tires (booo) and as for the gearing, I couldn't tell ya.
Offline Whiskeymetal
Re: Gas mileage
« Reply #3 on: September 23, 2008, 04:20:57 PM »
I heard having those Flames Flags on your vehicle gives it bad gas mileage...  :o
'99 With 31's
Re: Gas mileage
« Reply #4 on: September 23, 2008, 04:31:29 PM »
only time i ever got good fuel economy was @ 80 or less.  drag will make a bigger difference than RPM's - shift to 4th for the hills like it was overdrive... most of us shift down or don't use 5th at all.
Offline barmanjay
Re: Gas mileage
« Reply #5 on: September 23, 2008, 04:48:54 PM »
try driving a 2.5 - 4 banger on the hwy and a rig coming full steeam the other way in a headwind,.. damnit,.. I have to shift down to 3rd to gain speed back up again. Poor soft top feels like it's gonna rip right off sometimes.
On occassion I do follow behind some rigs to cut down on drag,.. easier on the pedal.
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline sylvrinvader
  • the micro wheeler
Re: Gas mileage
« Reply #6 on: September 23, 2008, 06:30:34 PM »
ive gone from stock tires to 31's ;D and have already noticed a change in fuel usage   :-\ :( :'( but i love the not so stock look
Offline Waytec
  • not all there
Re: Gas mileage
« Reply #7 on: September 23, 2008, 08:40:15 PM »
I am very sorry to tell you that if you are concerned about fuel mileage a jeep is one of the last vehicles that should have been considered.
If your engine is lugging you need to be down shifting. Listen to your engine for when to shift.
The obstacle is the path.
Offline BEZZ
Re: Gas mileage
« Reply #8 on: September 23, 2008, 08:58:04 PM »
I thought my gas mileage had got to $%@# then realized that my front left 33 was at 8psi!  Thats a lot of rubber to try and push!
Buy some safety glasses.
You can jackoff with a fake hand but you cant see out of a glass eye.
Re: Gas mileage
« Reply #9 on: September 23, 2008, 09:39:57 PM »
hehehehe, get a V8 guys................ 33s are nothing lol..........
Re: Gas mileage
« Reply #10 on: September 23, 2008, 10:10:40 PM »
My 5,750 lb, 381 HP V8 equipped, 10,100 lb towing capacity fullsize truck gets an average of about 19-20 mpg, combined city/highway. A recent 550 km highway trip delivered 11.9 L/100km or 23 mpg.
I just don't understand why the Jeeps suck so much fuel, brick shape or not.
Vince
Offline 4PLAYZJ
Re: Gas mileage
« Reply #11 on: September 24, 2008, 08:19:12 AM »
93 Grand cherokee 4.0L, around 5000lbs 36" bias ply tires and I get 12-14 mpg.  Not too shabby considering it was rated for an average of 16mpg new.  I think that the trick in fuel saving is in the gears.  I run 4.88's which puts my overall gear ratio with 36's higher than stock.
Offline 4PLAYZJ
Re: Gas mileage
« Reply #12 on: September 24, 2008, 08:59:04 AM »
Not true only the Oilers flags give you bad gas mileage :P :P
http://www.youtube.com/watch?v=LgpYG93gVEU
« Last Edit: September 24, 2008, 09:01:58 AM by ADRC »
Offline Tinkerer
    • My (OLD OLD OLD) website
Re: Gas mileage
« Reply #13 on: September 24, 2008, 09:31:11 AM »
I went to larger tires and compensated for the difference in odometer and speedometer readings using GPS etc.  Having done that, I can say it felt like I was accelerating more slowly even though I wasn't, but since I didn't change gearing, I also had to work the engine harder to get the same "feel" of acceleration.  Like I said above, I actually was accelerating pretty much the same, but the lack of engine revving made it seem to me that I was accelerating more slowly. Watching the actual speed etc. showed that it was about the same.
Since putting on the new tires, I got a ScanGauge II and used it to adjust my driving (which annoys the cr*p out of impatient drivers) and I'm now getting about 25% better mileage than I did with the factory tires.  For example, I now get about 500KM out of a tank instead of 400KM. I accelerate more slowly, but seem to catch up to the group once I'm up to the speed limit, never mind at the next red light! It's a lot less wear and tear on the entire drivetrain, including brakes, clutch, tires etc. due to the more smooth driving. I drive more by throttle opening than speed, so my speed does drop off on hills, though I don't let it get crazy and drop a gear to stay "close" to the speed I was doing.
I also concur that with speeds over about 70KPH, the drag increases considerably based upon the required throttle opening to maintain a given speed.  80KPH is pretty much the best compromise, though I usually do 90KPH with decent results.  Once I go to over 90KPH, the mileage drops off  significantly.  Numbers?  Well, on the highway at 80KPH on fairly flat terrain, I can get under 11L/100KM and sometimes can get that in the city too. My "typical" is high 12's and low 13's on anything but a short hop.
The caveat is that I didn't have the ScanGauge with the factory tire size and so didn't have the benefit of the driving changes for a fair comparison.
The subject of throttle opening versus gearing versus RPM etc. is a pretty complex subject, hence why engine computer programming is an arcane "art" ;D  Sure, it's easy to say that "everything else equal", the less RPM, the less fuel used, however it's that "everything else equal" that gets you.  If there is a corresponding increase in load due to the lower RPM (higher selected gear or bigger tires or lower numerical gearing), then chances are the computer is enriching the air/fuel ratio, so for a given RPM, more fuel is used.  It's a trade-off and without the ability to reasonably accurately measure things in real-time, it's very tough to determine what works best.  Oh yes, I did discover that when my mileage was dismal one day, that my tire had also dropped to 8Lbs or less for some reason.  The basics apply, maintaining engine tune (air filter, clean engine, spark plugs, wires etc.), slick lubricants, regular chassis lubrication and maintenance, optimal tire pressures, minimize stuff causing drag, smooth driving etc.
Egads... enough rambling..   While I don't buy a Jeep for good mileage, that doesn't mean I don't want to get the best mileage out of it that I can while still having fun!
LT285/75R15 Trxus MT's
VE6PDB - usually on VE6RYC
Re: Gas mileage
« Reply #14 on: September 24, 2008, 12:03:35 PM »
hahaha very very true! But who is stupid enough to even put one of those Oiler flags on their vehicle!
'99 With 31's
