Author Topic: U-joints  (Read 1056 times)
Offline Shearcon79
U-joints
« on: August 21, 2008, 09:08:45 PM »
anyone know where I  can get a 1310/1330 combo U-joint?  I bought my new drive shaft from DSI and didn't realize that the rear yoke in 94/95 YJ's is 1330.
Green 94 4.0 YJ :
4.5" RE Extreme Duty
Tera-flex Super Short SYE
Drive Products CV Driveshaft
Offline Rookie
Re: U-joints
« Reply #1 on: August 22, 2008, 06:10:42 AM »
Pats driveline or DSI should have them
Or you could change the yoke to a 1310 yoke then no special parts are required , you can get 131o joints anywhere
TJ with some stuff
Offline fug
  • Airdrie Pick n Pull
Re: U-joints
« Reply #2 on: August 22, 2008, 06:17:12 AM »
I Second changing the yoke to make it easier.  I was going to run the combo joint but decided to just change out the yoke so everything was 1310.
I did buy a combo joint at one point tho... think I got it at Napa.  I may still have it around if you are really interested... brand new in the box.
Fug
TJ Rubicon
Re: U-joints
« Reply #3 on: August 22, 2008, 07:09:32 AM »
I ran a combo joint in my YJ for a couple years before I got a CV driveshaft.  They can cause vibration and I would definitely recommend changing the yoke to a 1310.  FYI, there are 2 different yokes for the D35 and they are different length
