4x4 Related Groups => Tech Talk => Topic started by: fire and ice on March 12, 2010, 11:07:05 AM
Title: TJ lift kits
Post by: fire and ice on March 12, 2010, 11:07:05 AM
Hope you all can help me with a 4" lift kit for the 2003 TJ, so many on the market and most if all look the same. i don't have a lot of cash for this but still want a good lift for a ground ponder. this will be for show only.
Title: Re: TJ lift kits
Post by: Joel on March 12, 2010, 11:34:29 AM
If your strapped for cash, 1 or 2inch body lift and 3inch coil spacers, and extended brake lines, and maybe a t-case drop.  Is probably the cheapest route if you don' t plan to off-road much and don't care too much about ride quality.
But if your looking for a lift kit, 3" OME kit is hard too beat in terms of functionality and ride quality.
Post by: Spinalguy on March 12, 2010, 12:11:41 PM
http://lmgtfy.com/?q=2003+tj+lift+kit+opinions (http://lmgtfy.com/?q=2003+tj+lift+kit+opinions)
Post by: fire and ice on March 12, 2010, 12:19:14 PM
How about a Rough Country Lift, found one here in Calgary for 599.00, and i can run 33x12.5 15. Any thing I should know about this lift????
Post by: JackstandJohnny on March 12, 2010, 12:20:41 PM
priceless Tom.
loved it.
Post by: Spinalguy on March 12, 2010, 12:26:03 PM
:D http://lmgtfy.com/?q=rough+country+4%22+lift+opinions (http://lmgtfy.com/?q=rough+country+4%22+lift+opinions)
Post by: Pookapotamus on March 12, 2010, 12:31:52 PM
LOL  :D :D :D can we have this stickied in to the frequently asked questions?
Post by: fire and ice on March 12, 2010, 12:41:13 PM
The newbe thanks you all for your help. Not to JEEP like.
Post by: Spinalguy on March 12, 2010, 12:45:25 PM
i'm just messin with you. just add'+jeep' to the link i provided and you will get many opinions and info.
 8)
Post by: hps4evr on March 12, 2010, 06:56:25 PM
if its all show, the a daystar 1" body lift, 2 " coil spacers and some rims with 3.5-4.0" back space will work fine, even get the zenon plastic flat flares for the little extar room and to keep the tires covered and legal. do all that for under 2000$ including installation at a shop.
Post by: muffintop on March 12, 2010, 07:50:25 PM
if its all show, the a daystar 1" body lift, 2 " coil spacers and some rims with 3.5-4.0" back space will work fine, even get the zenon plastic flat flares for the little extra room and to keep the tires covered and legal. do all that for under 2000$ including installation at a shop.
Joel & hps4evr pretty much nailed it... what they didn't tell was why. Here is the why.
If its all just for show... you don't need to spend money on stronger control arms, springs, sway bar disconnects, quality rod ends, shocks, etc.
So... a 2" spacer lift:
1) Doesn't require a SYE and CV shaft (installed... this can cost as much as a 1/2 decent lift kit alone)
2) Doesn't require a T-case drop (cheaper but cheesier alternative to a SYE & CV shaft)
3) Doesn't require new springs (less cost)
4) Utilizes your stock control arms (less cost)
5) Will be quicker to install (less cost)
6) In combination w/ a 1" body lift & flat flares give you body clearance for 33" tires
Understand though... that this will pretty much get you a crap lift for anything offroad.
If you think your going to wheel (semi- serious w/o breaking stuff in the bush) at some point... consider investing in:
1) 4" Rough Country X-Series lift w/ SYE & CV shaft (Pretty decent single flex kit)
2) 4" Currie Enterprises lift w/ SYE & CV shaft (Top quality double flex kit that will last 100,000Km plus)
With all that said... I am surprised you didn't get flamed harder for posting "for show only"... most, if not all, guys on here build their rigs to go wheelin and don't care much about show. Looks like its your lucky day and actually got some decent advice  ???
Post by: Rubicon Josh on March 13, 2010, 01:05:39 AM
I had big plans for my jeep until the economy went for crap. I went from a $10,000 build budget to $2,000. This is my jeep below. Keep in mind that I started with a rubicon and I had made several changes over the past 5 years. The lift is 4" and cost $1450 for long arms. It isn't perfect but it is better than stock. I am running 35" KM2s.
(http://i619.photobucket.com/albums/tt280/fastnewt/P1040580.jpg)
(http://i619.photobucket.com/albums/tt280/fastnewt/P1040576.jpg)
(http://i619.photobucket.com/albums/tt280/fastnewt/DSC_0056.jpg)
(http://i619.photobucket.com/albums/tt280/fastnewt/DSC_0073.jpg)
Post by: muffintop on March 13, 2010, 06:50:30 AM
Rubicon Josh...
Nice highline body kit. I take it... its from AEV?
http://www.aev-conversions.com/products/highline/
To go 35's... I went w/ 4" lift & flat fenders simply for durability out on the trails. The dent in that sweet AEV hood must have hurt  :(
fire and ice...
This pic is a 2" spacer lift, no body mods & 33's
(http://i805.photobucket.com/albums/yy338/Jeepin_09/Stocker/P1010456.jpg)
This pic is a 4" lift, no body mods & 33's (white letters out & tire shine on lock  :-[)
(http://i805.photobucket.com/albums/yy338/Jeepin_09/4%20inch%20lift%20with%2033s/P1010481.jpg)
This pic is the same 4" lift, flat fenders & 35's (no tire shine  ;D)
(http://i805.photobucket.com/albums/yy338/Jeepin_09/1997%20TJ/P1010060.jpg)
Just a cool pic (showin off my AEV stuff too  ;))
(http://i805.photobucket.com/albums/yy338/Jeepin_09/McLean%20September%2026%202009/Picture001.jpg)
Post by: Rubicon Josh on March 13, 2010, 08:20:53 AM
Dent?! Nope it'sjust the lighting in the shop. I hardly have a scratch. My fender flares are a little beat up from running 35" tires with just 2" coil spacers.
This is the jeep before the lift.
(http://i619.photobucket.com/albums/tt280/fastnewt/P1040043.jpg)
Post by: muffintop on March 13, 2010, 08:32:41 AM
Good to hear... hate to see nice high end stuff get wrecked  :o
Post by: Rubi03 jef on March 13, 2010, 10:21:56 AM
ok so first off you should of got a H2 if its for show and you dont want to get it dirty
but that being said i have a 4 inch rough country lift super flex its great works awesome off road for a short arm kit
but thats not what your looking for your looking for easy cheap and not functional
so 2 inch body and 2 inch spring spacers would get your the height you are looking for to run 33's
i have 35's under mine and i rub a bit at full flex
my brother is running rough country 2.5 springs and 1.25 body giving him just under 4 inches of lift and he has 33's and they dont rub and it all costed under 350$
so thats probably your best bet and with out having a shity drive
