4x4 Related Groups => Tech Talk => Topic started by: halfcRoOk on March 31, 2011, 09:46:08 PM
Title: Home made quick disconnects?
Post by: halfcRoOk on March 31, 2011, 09:46:08 PM
Has anyone made there own quick disconnects? if so any pictures or sotries! maybe comments? haha
I'm thinking of cutting the sway bar arms adding a piece of tubing drill some holes and put some quick disconnect
pins!
Title: Re: Home made quick disconnects?
Post by: cLAY on March 31, 2011, 10:07:02 PM
I made a set years ago. They were a pain to get done up(comapared to bought ones anyway) and never were quite tight enough. If you cann'y afford a set just replace the locknuts on the threaded top portion of the link with regular nuts and lube the threads often. Then just keep a wrench handy to back them off and then spin the nuts off.
Post by: halfcRoOk on March 31, 2011, 10:11:29 PM
Haha! sweet thanks, I guess that could work! I'll try n find some nut n bolt I could replace it with, I have some laying around im sure
Post by: TL-Iguana on March 31, 2011, 10:55:20 PM
You can also look at this,
http://4x4xplor.com/homediscos.html
Or check out www.naxja.org for ideas
I don't condone the use of home made disconnects, as personally I feel you would be safer and best off buying a decent set, that's manufactured to spec... But for a temporary solution, that link is pretty straight forward. Even the suggestion Clay gave you is good, unless you snap the tops off trying to unbolt them :) If you ran with the above link, I'd carry extra clevis pins in your glove box, and add a washer on the end of the pin prolong its life. Perhaps even talk to a welder on here to get them to tack it on to make the head a bit larger so it doesn't try to suck through the hole.
Post by: cLAY on April 01, 2011, 09:10:33 AM
I built something likethat once. After a while the spring clips got all bent out of shape as they would get stuck in the pin.
Post by: halfcRoOk on April 01, 2011, 12:40:03 PM
ah! alright, thanks for the help guys, ill work on that!
Post by: Elsifer on April 06, 2011, 08:22:39 AM
I use the 4" long carpenters lag bolt? At least that what I think they are called.
A long hex bolt. Threads on the end, and the shank is not threaded. I think they come in Gr5 and even Gr8. Though, they are awful long to be of any use as Gr8.
Basically, cut the hex head off, drill a hole thru the shank for a cotter-pin, using two nuts, one on either side of the axle mount, tighten, viola. You now have a pin/stud to slide the eye on the lower end of the sway-bar link on.
https://elsifer.kicks-arse.org/gallery3/index.php/Jeep-Stuff/Jeeps/PA110004
Click on the picture, it will come full size, and you can have an idea.
Post by: TL-Iguana on April 06, 2011, 08:45:28 AM
It would seem your link is dead.  :(
Post by: Elsifer on April 06, 2011, 09:09:53 AM
replace the "arse" in the url with the more common three letter version
Post by: vantagetes on April 06, 2011, 02:10:36 PM
How much lift do you have? I have a pair I'll give you for $10. I think they do 2-4" lift, just shoot me a pm.
Post by: Elsifer on April 06, 2011, 02:29:41 PM
The lift used to be about 2". She has settled since. And my rig is no longer my daily driver. So I'm pretty happy with my Home Depot disconnects!
Thanks tho.
halfcRoOk could use em for $10, they'll be cheaper than his tubing setup.
