Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Axle shaft runout
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Axle shaft runout (Read 1215 times)
dac
That CB Yapper
Axle shaft runout
on:
October 17, 2008, 05:34:15 PM »
Does anyone know what the acceptable axleshaft and flange run out on a D44 rear is?
Logged
This is not 'Nam, this is wheeling. There are rules.
Bnine
Talks waaay too much!
Sticky Fingers
Re: Axle shaft runout
Reply #1 on:
October 20, 2008, 12:25:13 PM »
Should be no more then 30-50 thou. If you can visibly see it as obvious run out, there may be an issue.
Check both sides to confirm if one is out by a considerable amount.
Logged
[email protected]
dac
That CB Yapper
Reply #2 on:
October 20, 2008, 05:48:25 PM »
I checked the passenger side flange with dial calipers, the runout is maybe 3 thou. The drivers side is is closer to 25 thou. I can't see the driver side move but the bearing race on that side has a couple of scores on it.
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
Axle shaft runout
