Author Topic: Axle shaft runout  (Read 1214 times)
Offline dac
Axle shaft runout
« on: October 17, 2008, 05:34:15 PM »
Does anyone know what the acceptable axleshaft and flange run out on a D44 rear is?
This is not 'Nam, this is wheeling.  There are rules.
Re: Axle shaft runout
« Reply #1 on: October 20, 2008, 12:25:13 PM »
Should be no more then 30-50 thou. If you can visibly see it as obvious run out, there may be an issue.
Check both sides to confirm if one is out by a considerable amount.
Offline dac
« Reply #2 on: October 20, 2008, 05:48:25 PM »
I checked the passenger side flange with dial calipers, the runout is maybe 3 thou.  The drivers side is is closer to 25 thou.  I can't see the driver side move but the bearing race on that side has a couple of scores on it.
