Author Topic: 04 tj air condtioner  (Read 4582 times)
Offline scott/kerri
« on: October 23, 2008, 05:03:39 PM »
I need to find someone with a 04 tj that has air....mine has to go to be recharged and no one at the dealer  seems to figure out the specs for it...please help....
Scott has the 04 tj...nickname itty bitty
Kerri has the 09 jk , 4 inch lift
Re: 04 tj air condtioner
« Reply #1 on: October 23, 2008, 05:25:05 PM »
What do you need exactly ?
« Reply #2 on: October 23, 2008, 05:42:25 PM »
the dealership should know what it needs. i work at a dodge dealership and all the specs and info of your jeep is a click away. dare i ask what dealer you brought it to?
« Reply #3 on: October 23, 2008, 05:59:37 PM »
if they are any good they can charge it by pressures.... probably only a 1.25 pounds or so.
Offline scott/kerri
« Reply #4 on: October 23, 2008, 06:12:33 PM »
I took it to the dealrship here in Canmore to put a new engine in it...after our little surfing the wave incident....took them over 2 weeks and they can not find the specs on it...i was told they need the numbers off the air system, was told to open the hood look on the system and get the numbers LOL...if we don't get these number by monday i don't get it charged.....will also be the last time my tj goes there.
« Reply #5 on: October 23, 2008, 06:17:13 PM »
nothing under the hood, or even underside of the hood?
many labels are right on the top of the rad, by the compressor....
Offline scott/kerri
« Reply #6 on: October 23, 2008, 06:19:36 PM »
i was told the specs that are right on the top of the air contioning unit
Offline scott/kerri
« Reply #7 on: October 23, 2008, 06:30:29 PM »
hubby who has the tj tonight will be home and better explain that for all the help so far....
« Reply #8 on: October 23, 2008, 07:02:35 PM »
Mine is an '06, automatic, sticker says PA6-263617. Not really specs. but that's all I see.
Also some #'s on the back bracket,(1/2 coverred by a bolt) I dunno about those telling anything about the charge ?
Offline scott/kerri
« Reply #9 on: October 23, 2008, 07:23:16 PM »
well sorry to say it was at canmore chrylser it is the last time it goes there. anyways i need the A/C  spects for  2004jeep tj because they dont have a clue.they tell me they can find any info on it on the internet.anyways if anyone has an 04 could you check for me  thanks
Offline Tinkerer
    • My (OLD OLD OLD) website
« Reply #10 on: October 24, 2008, 06:33:08 AM »
I've heard bad things about the dealer in Canmore... gal I know that lives there and drives a Jeep takes it to the Ford dealer, the only one she swears by, but then she knows someone there :)
I'll look at my system tonight... the dealer should be able to find whatever they need on the dealer system as someone pointed out.  They are being lazy or stupid... pardon for being so blunt, but I calls 'em as I sees 'em.
I'll also check my FSM for my '04 Rubi.
LT285/75R15 Trxus MT's
VE6PDB - usually on VE6RYC
« Reply #11 on: October 24, 2008, 02:29:20 PM »
MANIFOLD GAUGE SET CONNECTIONS
CAUTION: Do not use an R-12 manifold gauge set
on an R-134a system. The refrigerants are not compatible
and system damage will result.
LOW PRESSURE GAUGE HOSE The low pressure
hose (Blue with Black stripe) attaches to the suction
service port. This port is located on the liquid line
near the evaporator inlet tube at the rear of the
engine compartment.
HIGH PRESSURE GAUGE HOSE The high pressure
hose (Red with Black stripe) attaches to the discharge
manifold directly over the discharge port of the compressor.
RECOVERY/RECYCLING/EVACUATION/CHARGING
HOSE The center manifold hose (Yellow, or
White, with Black stripe) is used to recover, evacuate,
and charge the refrigerant system. When the low
or high pressure valves on the manifold gauge set
are opened, the refrigerant in the system will escape
through this hose.
SPECIFICATIONS
A/C APPLICATION TABLE
Item Description Notes
Vehicle TJ Wrangler
System R134a w/orifice
tube
Compressor Denso 10PA17 ND-8 PAG Oil
Freeze–up
Control
Low Pressure
Cycling Cutout
Switch
Accumulator
Mounted
Low PSI Control Opens < 20.5
psi - Resets >
38 psi
High psi Control Switch Opens >
450 - 490 psi -
resets < 270 -
330 psi
Discharge Line
Mounted Switch
Control Head Manual Type
Mode Door Vacuum
Blend Air Door Electric
Actuator
Fresh/Recirc
door
Vacuum
Blower Motor Control Head
Switched
Resistor Block
Cooling Fan Viscous Fan 4.0L Engines
Only
Cooling Fan Electric Fan 2.4L Engines
Only
Clutch
Control Relay PCM
Draw 2 - 3.9 amps @
12V
± 0.5V @ 70° F
Gap 0.0169 - 0.0319
DRB IIIT
Reads TPS, RPM, A/C
Switch Test
Actuators Clutch Relay
24 - 10 HEATING & AIR CONDITIONING TJ
« Reply #12 on: October 24, 2008, 03:02:23 PM »
on an R-134a system. ..............
didn't say how much of a charge to put in.....
« Reply #13 on: October 24, 2008, 03:14:27 PM »
This stuff ?   ;D
Refrigerant Oil Capacities
Component ml fl oz
A/C System 180 6.1
Accumulator 90 3
Condenser 22 .75
Evaporator 45 1.5
Compressor
drain and measure
the oil from the old
compressor as noted
« Reply #14 on: October 24, 2008, 03:21:39 PM »
No...
there will be some sort of a lable "somewhere" stating how much refrigerant (R134a) there is in the system. A charge is weighed in, so the lable will be in lbs, or kgs, not fl oz, or mL.
That stuff is info on the oil (POE) that components will hold.
Scott/Kerri... did the shop pressure test, and evacuate the system properly, yet? I am going to guess NO, since they can't/won't charge it up....
