Author Topic: Strengthen a D35  (Read 4249 times)
Offline Waytec
  • not all there
Strengthen a D35
« on: October 29, 2008, 05:33:29 PM »
I am in need of some suggestions for how to strengthen a D35.
I have been wanting to re gear and locked my rear end since about my 3ed trip out. But the cost to gear and lock a 8.25 is superiorly more then a 35. Also used parts are allover the place for them. So I have gotten a D35 and a used locker and am going to put it under my Cherokee.
 Before I do so I want to strengthen the D35 first. This done all the time but I can not find info about how to do so. So any suggestions or links on how to do so would be great.
The obstacle is the path.
Re: Strengthen a D35
« Reply #1 on: October 29, 2008, 05:44:17 PM »
Thought you had the 8.25 in the rear?
« Reply #2 on: October 29, 2008, 06:03:45 PM »
The phrase "polishing a turd" pretty much sums up the wisdom of putting money into a "turdy5".
Look for a D44, 8.25, explorer diff........
Offline calltrex
« Reply #3 on: October 29, 2008, 06:13:29 PM »
96+ explorer 8.8 diff  with disc brakes
Id rather have the 8.8 open then the wimpy D35 locked
if u can live with drum brakes instead pre-96 you can get a 8.8 for $100
I bought one for $100
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Offline Waytec
  • not all there
« Reply #4 on: October 29, 2008, 06:18:48 PM »
I have an 8.25 now and D44's people want left arms for. So far I have less then $100 into a D35 that is geared and a ARB locker. I can reinforce this diff and have no issues unless someone has an 8.25 or a D44 geared and locked for me at those prices. I will take it.
Back to the issue at hand. How is the best way to reinforce a D35.
Offline sylvrinvader
  • the micro wheeler
« Reply #5 on: October 29, 2008, 06:20:00 PM »
as far as i know use a truss
« Reply #6 on: October 29, 2008, 06:56:59 PM »
Truss might help the axle tubes, but all of the internals are still going to be junk. A locker will only make them break easier.
« Reply #7 on: October 29, 2008, 08:19:13 PM »
Not always the case if you understand the forces.  It is usually high instantaneous stress that breaks the shafts like when you are spinning a tire and suddenly get traction.  It is true that locker do put a higher continous stress on the shafts which can aid in breaking a shaft
Now I locked my D35 with an ARB and I actually felt safer than when I was open.  The reason being is that I did not need nearly as much momentum or skinny pedal to go hills or tough obstacles.
Since you are set on building a D35 and you probably don't have a super kit in there, I would look at truss the housing and getting alloy shafts.  With that combo you should definitely be okay with 31s and if you make the step to 33s for awhile.  A lot of people jump on the brand wagon and bash the D35 but 31s or 33s it can be a decent axle if built right and the driver realizes it a D35.  Denise's D35 took a CRAP load of abuse and last a long time
Offline Waytec
  • not all there
« Reply #8 on: October 29, 2008, 08:53:18 PM »
Thanks Scott
I will defiantly look into a super kit. As for a truss is their anywhere I can go to get info about putting a truss on.
Offline calltrex
« Reply #9 on: October 29, 2008, 09:08:38 PM »
is it a c-clip or non c-clip ??
........___________
.../""""/........J
Offline Waytec
  • not all there
« Reply #10 on: October 29, 2008, 09:22:25 PM »
non c-clip
« Reply #11 on: October 29, 2008, 10:08:34 PM »
Check out Mountain Valley Customs, they have a truss/skid that a few guys on JF run.
« Reply #12 on: October 30, 2008, 07:18:39 AM »
The Super kit requires a new locker as it is 30 spline shafts, but I would talk to ARB and ask is you can just swap the spider gears for some 30 spline ones.  I know you can do that on the newer D30 ARBs
Offline Gearhead
« Reply #13 on: October 30, 2008, 07:27:11 PM »
Not to be negative like on pirate 4x4 BUT .............................
As mentioned
You could go ahead with your plan anyway .  At this stage it appears inexpensive when in fact , if it grenades , leading to a second axle build  / repair  or aquisition / build if it blows up real good , the cost could be a real shock if you are not prepared for it.  I should mention the potential hassle of dragging it out of the back country , towing , etc.
Here's a D35 shaft  next to a D44 (Waggy)
If you build it and it breaks , the ridicule and guffawing could get outa hand , hope you don't mind some teasing.
Lots of us  have run D35's , I still own two vehicles with D35's neither of them get wheeled or do any towing. I've also seen Dana 35's survive a savage pounding a number of times as well as snap an axle turning a corner at the mall.
Think it over before spending money.
Offline Waytec
  • not all there
« Reply #14 on: October 30, 2008, 08:14:17 PM »
Because Gearhead is so set on me not building a D35 I guess he will gladly trade me a D44 with a air locked and gears for the D35, locker and gears I have now. So Pm me with your address and I will come by this weekend to get it.
