Author Topic: spool  (Read 3389 times)
JaydarXJ
spool
« on: October 18, 2005, 05:35:25 PM »
lookin to get a spool for the XJ's rear, who is the best to see about these? I was thinkin Pat's driveline, any better suggestions? :)
8inchesofxj
spool
« Reply #1 on: October 18, 2005, 05:46:05 PM »
if you have the dana 44 rear i would just go to national but if your looking to find one for a dana 35 good luck.  Ive called probably everyone in calgary that sells full spools and mini spools and no one carries one for a dana 30/35.  if you find some one who sells em let me know also i went to the gear center (pats) and they dont have em
spool
« Reply #2 on: October 18, 2005, 07:36:55 PM »
Its cheaper to just remove the carrier and have a welder, weld the side gears up. I don't recommond this on a D35 though and I would suggest this only be done on a trail only rig. I've driven a few different trial rigs now with welded rears and I would not do it to something thats driven on the street for much more than just getting to and from the trails.
JaydarXJ
spool
« Reply #3 on: October 18, 2005, 08:21:30 PM »
it has the chrysler 8.25 axle with a posi
Offline midnightcowboy
spool
« Reply #4 on: October 18, 2005, 09:24:00 PM »
cant you just shim your posi up tighter to act like a locker? ive heard this is possible........
JaydarXJ
spool
« Reply #5 on: October 18, 2005, 10:21:16 PM »
I've never heard of that, I'll have to do some reserch. :?
HBZ
spool
« Reply #6 on: October 19, 2005, 08:24:56 PM »
I don't know of any spools made for the 8.25".
Your best bet, if you aren't dd, is a Lincoln Locker.
If you go to the mall, you probably won't get in or out
of a parking stall with it this way!!
 :wink:  :wink:
JaydarXJ
spool
« Reply #7 on: October 19, 2005, 09:07:47 PM »
Quote from: "HBZ"
what is dd ? Daily driver?
Why would the Lincoln not be good?(can't be worse than a spool)
What is the price for one?
spool
« Reply #8 on: October 19, 2005, 09:54:37 PM »
Lincoln Locker aka Welded Diff, but they are only as strong as your welding
JaydarXJ
spool
« Reply #9 on: October 19, 2005, 10:19:57 PM »
ahhhhh, I see.
I was thinking of welding it, can it be done on a posi?(I don't have it apart to look yet) :)
CanaMatt
spool
« Reply #10 on: October 20, 2005, 12:34:41 AM »
I know what a spool is, but whats a mini spool?
JaydarXJ
spool
« Reply #11 on: October 20, 2005, 01:52:17 AM »
mini spool just replaces the spider gears and keeps the stock housing, full spool replaces the whole thing :)
spool
« Reply #12 on: October 20, 2005, 09:34:04 AM »
Welding the diff has the same effect as installing a spool(except you have more $$$ in your pocket in the end). I don't reccommend either for a DD(daily driver) or semi-daily driver.
You can weld up a posi diff but its a bit of a waste. Find an open diff and then sell your posi, or find someone to trade.
Offline BrokenAxle
    • Broken Axle home page
spool
« Reply #13 on: October 20, 2005, 10:30:52 PM »
if the posi is any good, i'd be more than happy to trade you.  i could even weld up the open carrier for you!
Dave
Offline Woolf
spool
« Reply #14 on: October 21, 2005, 07:28:38 AM »
Same goes man...if you're diff's got 4.10's and the posi's in good shape I'll swap you for an open diff and get it all welded up for you.
