Author Topic: tow points for a KJ  (Read 1953 times)
tow points for a KJ
« on: January 12, 2009, 03:09:29 PM »
Anyone want to comment on the strength of this setup?
http://www.lostkjs.com/forum/phpBB2/viewtopic.php?t=9316
Re: tow points for a KJ
« Reply #1 on: January 12, 2009, 08:41:20 PM »
I should explain better....will the drop part of the hitch hold up to a tow strap? Obviously from the way they are attaching it to the frame, that part has strength. Just wondering about the part where the ball attaches onto the hitch.
« Reply #2 on: January 12, 2009, 09:11:53 PM »
He already bent the grade 5 hardware....won't be long before someone gets hurt.
P-Dubb
« Reply #3 on: January 12, 2009, 09:15:58 PM »
if its bolted. i thinks its not a good idea.. weld maby?.. my 2 cents.. i hate bolted hooks  >:(
« Reply #4 on: January 12, 2009, 09:19:27 PM »
He replaced them with Grade 8 bolts.
How does bolting a hitch receiver become less solid than a bolted tow hook?
And honestly....I'm asking about the end of the drop hitch....not how it's mounted.
Offline sylvrinvader
  • the micro wheeler
« Reply #5 on: January 12, 2009, 09:26:35 PM »
well if its street legal to pull a trailer i think it should be strong enough to take some good tugs
« Reply #6 on: January 12, 2009, 09:27:53 PM »
I would think that everything would be rated for 10,000lbs, or so, depending on what drop hitch you purchased. Why wouldn't it be strong enough? If you are concerned with the weld from the shaft (hehehe.... shaft) to the drop.... isn't it rated on the shear strength? as far as I remember.... the pull strength is far stronger than the shear strength. (maybe a welder could pipe in to confirm).
« Reply #7 on: January 12, 2009, 10:47:28 PM »
Those are things I don't know about.  Towhook thought it was a great idea.  I know it could be bolted to the frame strong enough, and I know the clevis can hold, but will the part where the clevis is attached come off the hitch receiver itself, or snap?
Otherwise, it looks like a great and easy setup.
« Reply #8 on: January 13, 2009, 08:52:55 AM »
Makes the bolts too long. (Same problem with body lifts)
Stronger then Grade 5 apparently, time will tell if it's stronger then grade 8.
« Reply #9 on: January 13, 2009, 08:55:58 PM »
Serge, how does that affect it, when the same amount of bolt will be going through the hitch receiver?
Quote
I don't think the problem lies in the mounting....just need to figure out about the pull and shear strength.
« Last Edit: January 14, 2009, 10:01:41 PM by dunl »
KrossLoch Fab
« Reply #10 on: January 15, 2009, 10:18:28 AM »
Not to call you wrong P-Dubb, but bolting is the way to go. Do not weld your towpoints to the frame rails.
Darcy, as we talked earlier, the amount of force it would take to tug a clevis/shackle through that hitch flat bar would be insane! And, even the welding of the falt bar should hold up to much greater force than we could put on with a tow strap etc.
« Reply #11 on: January 15, 2009, 05:16:04 PM »
C, you dork. how many aliases do you have now?
 ;D ;D ;D LMFAO!!!
KrossLoch Fab
« Reply #12 on: January 15, 2009, 09:23:36 PM »
 ;D ;D ;D LMFAO!!!
Lots!!!HAHAHA!
Seriously though? My other computer blew up with all passwords etc on it! Couldn't get back on here for the life of me!LOL
