Author Topic: Water in front diff  (Read 2015 times)
joker
Water in front diff
« on: April 01, 2009, 10:41:14 AM »
in my 05 tj. is it a tough fix or something i can do my self?
Online fug
  • Airdrie Pick n Pull
Re: Water in front diff
« Reply #1 on: April 01, 2009, 10:44:41 AM »
It's pretty straightforward and you're going to get good at it if you wheel alot ;)
Remove cover, drain bad oil/water out, clean up cover/diff mating surfaces, apply liberal amounts of RTV, bolt cover back up, fill with your favorite gear oil
Fug
TJ Rubicon
Offline Immortal
« Reply #2 on: April 01, 2009, 10:50:08 AM »
has anyone here tapped in a drain/plug for this very reason?
if we were smart with our money we wouldn't own Jeeps.
Here's your cup of STFU... ENJOY!
Offline dac
« Reply #3 on: April 01, 2009, 11:02:48 AM »
Would it be worth getting an aftermarket diff cover for protection?  As expensive as they ar the ARB's are nice because they have the drain plug, but at the same time maybe it'd be better to take a peak inside when you change the oil?
This is not 'Nam, this is wheeling.  There are rules.
Offline Immortal
« Reply #4 on: April 01, 2009, 11:11:19 AM »
hmmmm.... good point re: inspection
Offline tubby
  • Life's too short for a fulltime job
« Reply #5 on: April 01, 2009, 11:29:16 AM »
You could also use a hand pump with a tube and slip it into the fill plug. Keep sucking old fluid until nothing comes out and re-fill with new oil.
Lockers
Cuz ya can't kick arse with only one leg
Offline JackstandJohnny
  • where Jeeps go to die
« Reply #6 on: April 01, 2009, 11:40:05 AM »
used to do that with my old Ford and the TTB front end. NOT fun; still don't know how much crap still sits in there, can't really inspect it either or clean the old stuff out. pull cover its easy, then u can check ur gears and stuff too for metal shards etc.
Offline tubby
« Reply #7 on: April 01, 2009, 11:49:08 AM »
Johnny,  thats funny cause I use to do that with my TTB also.
I found enough sand to fill a sandbox in my Bronco's diff. I'm not kidding.
I've never seen what the internals look like, and I don't want to know.
Lockers
« Reply #8 on: April 01, 2009, 11:55:00 AM »
i saw them once..... when we did a gear swap........... all i can say is: i'm really, REALLY glad we were doing the gear swap.........
Offline mike s
  • Good times!
« Reply #9 on: April 01, 2009, 12:45:15 PM »
Drill and tapping stock housing is a great idea. Use a magnetic drain plug to catch particles and hold them out of harms way- every eat bubble gum and potato chips at the same time? As so far as inspecting gears while servicing fluids, you'll hear the problem well before you see it. Check diff vent while your getting dirty. Seen tons plugged up and when you get that hot diff cold- like dunking it in cold water/mud, it cools and contracts creating a vaccum inside pulling water by the axle seals. Best to run a new hose way up high with a see-through fuel filter in the end to keep crud out.
'94 YJ, 2.5" RE, 1"BL on 35"s, 8.8 w 4.88
oldEnuff2NObetter
but still can't help myself
Offline tubby
« Reply #10 on: April 02, 2009, 08:12:41 AM »
Another idea would be to use a clear diff cover . If you wheel through a lot of water and want to inspect your fluid a lot. Trans Dapt makes one for a Dana-30 that uses the same material as bullet-proof glass. Looks cool.
Lockers
Offline calltrex
« Reply #11 on: April 02, 2009, 10:44:42 AM »
the ruby D44s have a drain plug.  I changed fluids in a flash
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Offline 01sahara
« Reply #12 on: April 02, 2009, 11:08:00 AM »
I like the ARB one, that is what I am upgrading to.
I will be selling a Rockcrusher diff cover for a Dana 35 next month when my new parts are in. $90 . No drain plug but much cheaper than the ARB.
« Last Edit: April 02, 2009, 11:55:30 AM by 01sahara »
Super Winch, 33" MT, 2 1/2" lift , CB, Flat Fender
http://melaman2.com/cartoons/singles/george-jungle.html
Offline newfie
  • newbie and loven it
« Reply #13 on: April 03, 2009, 09:26:37 AM »
why ya swaping out the Rockcrusher for the ARB if ya dont mind me asking
newfies are everywhere
Offline XJHERO
  • Soberphobic
« Reply #14 on: April 03, 2009, 09:28:55 AM »
drain plugs and magnets on drain plug and dipstick
oh and probly cus he has a arb air locker in it.
 ;D
Like ivry soap....pure as frack
DD
Get at me Wolf
