Author Topic: lifting?  (Read 4017 times)
Offline jandh
Re: lifting?
« Reply #15 on: April 18, 2009, 11:13:35 AM »
I'm moving this out of Jeep Stuff Wanted - because I'm continuosly keeping it off topic
Quote from: WagoneerXJ on April 12, 2009, 06:38:55 PM
Well some people use 80's or 90's F-150 coil springs. I'm told it gets you about 3" of lift, but rides like arse because they are really stiff (meant for a fullsize truck with a V8 afterall)
How many inch's can you lift before you have to start changing other parts too? ie. control arms
Say from stock if I went with the Leaf springs from a S-10 then the front coil springs from a F-150 that would give me about 4 inch's in the rear and 3 inchs in the front (sound right?)   would I have the change anything else or can i just go to PNP and get rear leaf springs and front coil springs?
I'm goign to pnp on saturday so I might grab this stuff
Bump
1991 YJ
ogilviexj
Re: lifting?
« Reply #16 on: April 18, 2009, 11:54:31 AM »
what time are you going to the PNP? Also, you can go as high as 3 inches before changing things like LCA and sway links.
Just to let you know, it might be a tough time ripping out the rear leafs at a pnp. How is your stock leaf, at least the one on top? collapsed? if not, then you can leave that in your truck and replace the bottem ones if in a pinch.
Good luck, seems like your in a hurry to change the looks of your xj.
Offline jandh
Re: lifting?
« Reply #17 on: April 18, 2009, 09:56:34 PM »
Lol Ya I am in a hurry, I want to get it ready and hopefully make that June event - I went to pnp and got Rear springs from a 89 Ranger just the two Help springs, will replace mine with those tomorrow, measured them and they are gunna fit, hope it will bring me up 2 inch above stock, but no garantee.  Got two front coil springs with 8 1/2 turns from a Grand Cherokee mid 90's style hope that gives me 1 1/2 above stock -    Then all I have to get is my tow hooks and I think i can do it.
Thanks for the info, once I get the cash Im goign to go to modern motors and get a 3 inch lift for like $500 bucks and that will be a probper lift, rather then me redneck'n it, but money's tight now so hopfully this works
1991 YJ
Re: lifting?
« Reply #18 on: April 19, 2009, 11:05:53 PM »
what lift is that? budget boost?
Offline jandh
Re: lifting?
« Reply #19 on: April 20, 2009, 07:11:13 AM »
Yeah more or less - It's a 2" lift all round   New leaf springs in the back and 2" spacers in the front - Budget boost
1991 YJ
Re: lifting?
« Reply #20 on: April 20, 2009, 10:33:11 AM »
if the Grand Cherokee coils you got are from a V8 it will lift the front 2".  If you want I can take picture of mine for ya.
Offline jandh
Re: lifting?
« Reply #21 on: April 20, 2009, 01:17:01 PM »
That would be awsome, Thanx
1991 YJ
Re: lifting?
« Reply #22 on: April 20, 2009, 04:04:09 PM »
You have the right springs, 8 turns with a small one on top
