Author Topic: lifting?  (Read 4017 times)
Offline jandh
lifting?
« on: April 13, 2009, 02:12:59 PM »
If I want to do a good lift to my XJ-  what would be a good lift - 3inch?      I want to keep the same size tries i have now, and make it still look and fucntion pretty good.  I got 235's on now, I think 16's but i havent checked - got the jeep on saturday ::)
I double check that size and reply - im at work, looking up jeep stuff, lol.
1991 YJ
Re: lifting?
« Reply #1 on: April 13, 2009, 09:08:21 PM »
if you dont want to change tire size then dont put a lift in it. get a better tire and rim. and maybe upgrade the dampers. spend your money on bolt on widgets and gidgets;) lol!
Offline jandh
Re: lifting?
« Reply #2 on: April 13, 2009, 09:23:14 PM »
235 75 15's  thats what i got on there now.
I want to upgrade my tires later on that what the lift is for, and looks, I love the look of a lift
1991 YJ
Offline jandh
Re: lifting?
« Reply #3 on: April 13, 2009, 09:36:21 PM »
oh, here's a question for you/s   If I don't do a lift, what are the largest tires i can safely go with? without rubbing when i turn
1991 YJ
Re: lifting?
« Reply #4 on: April 13, 2009, 09:47:18 PM »
LT235/75R15... maybe a 30/9.50R15...
a 3inch lift should clear 31" on stock offset rims.
Re: lifting?
« Reply #5 on: April 13, 2009, 10:45:53 PM »
So that's not your jeep in your picture?
Offline Pookapotamus
Re: lifting?
« Reply #6 on: April 14, 2009, 07:32:47 AM »
I gave my stock XJ a 2" budget lift, this consisted of front spacers ($40 modern moters) and ranch leafs that are 2" higher than factory ($200 modern motors) this lift was cheep, did not affect any other parts on the XJ and did not affect the drivability of the jeep at all. it also gives a much nicer stance and does not give too much fender gap. i did this for the same reason, to fit nicer more aggresive tires on my XJ (although i cant afford them at the moment). also if you are planning to go higher in the future this is a cheep starter lift.
hope this helpes
Offline jandh
Re: lifting?
« Reply #7 on: April 14, 2009, 07:40:51 AM »
Ok now the pic is my jeep
hope this helpes
Yeah that does help - Thank-you,  where is modern motor? online?  or is that even a store, lol.
« Last Edit: April 15, 2009, 03:22:48 PM by jandh »
1991 YJ
Re: lifting?
« Reply #8 on: April 14, 2009, 07:53:39 AM »
modern moters is in between 53 ave sw and 58 ave sw on the west side of blackfoot. they are online but it is much easier to just go in.
Offline jandh
Re: lifting?
« Reply #9 on: April 14, 2009, 01:55:10 PM »
Thanx, thats acctually really close to my place
1991 YJ
Re: lifting?
« Reply #10 on: April 15, 2009, 08:13:45 AM »
@ jandh you must be really close to me as well, i am just over on heratage in between fairmont and blackfoot.
Offline jandh
Re: lifting?
« Reply #11 on: April 15, 2009, 03:16:32 PM »
Yeah i am close, lol-  allandale close - between Heritage and Where acadia drive turns into a st.  I live really close to a little strip mall thats on 6th
pretty much accross the street from you ,a 1 minute drive
that's pretty cool
« Last Edit: April 15, 2009, 03:21:09 PM by jandh »
1991 YJ
Re: lifting?
« Reply #12 on: April 16, 2009, 07:15:28 AM »
if you need any help just pm me i am always up for some wrench turning! ;)
Offline jandh
Re: lifting?
« Reply #13 on: April 16, 2009, 09:24:34 PM »
Ya no prob, I'm acctually changing the read axel bearings tomorrow but not sure what time.  Have a tire change tomorrow morning first come first serve, then a quick trip to pnp to get some rear leafs to spruce up my back end  then I'll be home to do the work if your interested in coming for a beer while we change some parts
1991 YJ
Offline jandh
Re: lifting?
« Reply #14 on: April 18, 2009, 09:20:07 AM »
I'm moving this out of Jeep Stuff Wanted - because I'm continuosly keeping it off topic
Quote from: WagoneerXJ on April 12, 2009, 06:38:55 PM
Well some people use 80's or 90's F-150 coil springs. I'm told it gets you about 3" of lift, but rides like arse because they are really stiff (meant for a fullsize truck with a V8 afterall)
How many inch's can you lift before you have to start changing other parts too? ie. control arms
Say from stock if I went with the Leaf springs from a S-10 then the front coil springs from a F-150 that would give me about 4 inch's in the rear and 3 inchs in the front (sound right?)   would I have the change anything else or can i just go to PNP and get rear leaf springs and front coil springs?
I'm goign to pnp on saturday so I might grab this stuff
1991 YJ
