Author Topic: best front diff options  (Read 1044 times)
FullMetalJeep
« on: May 13, 2009, 11:05:18 AM »
looking for idea's on what would be the best front diff swap options for a tj. I want to keep the track width as close to a stock TJ as possible as I dont have the means to shorten and modify the axles too much on my own.
So, the idea would be a front Dana 44 or Dana 60.
In the mean time I am looking for a direct bolt in TJ44 but dont have a lot of cash, and am not in a hurry. So entertaining the idea of building up a front from the scrap yard, unless I magically find a front TJ44.
The shortest track width 44's I know of would be out of an IH or Bronco. But thats where the knowledge ends.
I dont know what would be a good donor for a 60.
Dont get me wrong, I am not too much of a lazy guy, I am doing my own research online, but would like a few pointers from the experiened guys here to help me narrow my search.
thanks.
Re: best front diff options
« Reply #1 on: May 13, 2009, 12:57:09 PM »
Depends on how big you want to go as to where you go D44 or D60 or something else. Check out the Wagoneer D44s, slightly narrower I believe
FullMetalJeep
« Reply #2 on: May 13, 2009, 02:35:12 PM »
is the wagoneer's diff the same size as all FSJ?
Offline XJHERO
  • Soberphobic
« Reply #3 on: May 13, 2009, 03:29:07 PM »
waggy=fsj
sum wide track some narrow
DD
Get at me Wolf
Offline boggincj7
« Reply #4 on: May 13, 2009, 09:46:53 PM »
Try and find an 80's wagoneer dana 44. They are a little beefier than a scout 44 and it will be driver side drop. It will be 60" WMS to WMS.  Try and find one with manual hubs. I think most are except for a couple years which I think was 83 and 84 , they had some kind of vacume setup IIRC. Some even have flat top knuckles. The bolt pattern is 6 on 5 1/2 so you will have to deal with that. Hope this helps.
81 CJ7,304,waggy diffs,SOA,OBA,warn 8274,and always modifying.
Lethbridge Coulee Kruzers
