Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
fan shroud or no fan shroud?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: fan shroud or no fan shroud? (Read 1040 times)
Corey
Guest
on:
May 19, 2009, 10:52:49 AM »
Pro's and con's? I want no shroud do easy cleaning will that bother anything? I have a 4.0ltr
Logged
JackstandJohnny
Talks waaay too much!
where Jeeps go to die
Re: fan shroud or no fan shroud?
Reply #1 on:
May 19, 2009, 10:54:47 AM »
good thing it will be easy to clean cause you'll get even more water/mud in there.......... will probably run a little warmer too,s pecially in the summer
Logged
~ rescue green JKUR on 35s. typical rubicon build
WhiteOut
Reply #2 on:
May 19, 2009, 10:58:28 AM »
You need one, I dont have a shroud and Im running a bit warm.
Logged
BlackYJ
Reply #3 on:
May 19, 2009, 11:11:13 AM »
Same issue here. I had issues with temp when I broke my shroud and now that I have replaced it, my temp has lowered back to normal operating temp. So from experience I would say a shroud is required
Logged
Evil-Jeep
UberWheeler
Reply #4 on:
May 19, 2009, 12:04:01 PM »
x3... shroud is best
Logged
strong
Guest
Reply #5 on:
May 19, 2009, 12:06:00 PM »
Very intetesting I just broke my shroud and took it off and have noticed the same thing as the previous posts.
Logged
GiS
That CB Yapper
Reply #6 on:
May 19, 2009, 12:19:25 PM »
I've got a shroud off a 4.0L I am not using....
But yes x11 or whatever, a shroud is essential.
Logged
Corey
Guest
Reply #7 on:
May 19, 2009, 12:41:47 PM »
Thanks for the imput
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
