Author Topic: fan shroud or no fan shroud?  (Read 1034 times)
Corey
« on: May 19, 2009, 10:52:49 AM »
Pro's and con's?  I want no shroud do easy cleaning will that bother anything? I have a 4.0ltr
Offline JackstandJohnny
  • where Jeeps go to die
Re: fan shroud or no fan shroud?
« Reply #1 on: May 19, 2009, 10:54:47 AM »
good thing it will be easy to clean cause you'll get even more water/mud in there..........  will probably run a little warmer too,s pecially in the summer
Offline WhiteOut
« Reply #2 on: May 19, 2009, 10:58:28 AM »
You need one, I dont have a shroud and Im running a bit warm.
« Reply #3 on: May 19, 2009, 11:11:13 AM »
Same issue here.  I had issues with temp when I broke my shroud and now that I have replaced it, my temp has lowered back to normal operating temp.  So from experience I would say a shroud is required
Offline Evil-Jeep
« Reply #4 on: May 19, 2009, 12:04:01 PM »
x3... shroud is best
“I contend that we are both atheists. I just believe in one fewer god than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours.”
strong
« Reply #5 on: May 19, 2009, 12:06:00 PM »
Very intetesting I just broke my shroud and took it off and have noticed the same thing as the previous posts.
Offline GiS
« Reply #6 on: May 19, 2009, 12:19:25 PM »
I've got a shroud off a 4.0L I am not using....
But yes x11 or whatever, a shroud is essential.
Corey
« Reply #7 on: May 19, 2009, 12:41:47 PM »
Thanks for the imput
