Author Topic: New solution to your overheating!!  (Read 2145 times)
FullMetalJeep
« on: May 21, 2009, 09:36:00 PM »
A buddy of mine that works at a bike/quad/skidoo shop and I were talking about my stupid over heating problems. He told me maybe I should try this new coolant they use called Engine Ice.
So I did some research and this stuff is great!! Too bad my damn rad has a hole in it due to me trying ways to modify the engine bay for heat reduction....
Here is a blurb from the site:
This just may be the most unbelievable product you have ever used; Engine Ice Hi-Performance Coolant is here!
Everyone wants better performance and our racing, riding and driving areas are diminishing because ecologists constantly claim we damage or permanently ruin the surrounding lands.
WE HAVE THE ANSWER!
Engine Ice Hi-Performance Coolant is biodegradable, phosphate free & non-toxic; while reducing operating race temperatures by as much as 50°F and effectively keeping boil over temperatures to 256 °F or less and freeze-up protection to -27° F.
Engine Ice Hi-Performance Coolant is premixed with de-ionized water to protect your water cooling system from scarring, scaling and to effectively provide "prolonged optimum operating temperatures."
"Right out of the bottle" Engine Ice Hi-Performance Coolant is "ecologically safer" than regular coolants for wildlife and the environment. What's even more amazing is that it works far better than most any other engine coolant on the market.
Because of Engine Ice Hi-Performance Coolant's non-toxic phosphate-free formula, it's even safer for people and pets too!
We at CycleLogic are avid racing enthusiasts since 1975 and we demand performance and we appreciate free, open areas made possible by our local and federal governments as well as private land owners. We recognize the "effort" it takes to "keep" them free.
Join our family and the other racing enthusiasts who enjoy our product.
At CycleLogic, we believe we are doing our part for the riders, the racers, our free lands, the environment & wildlife.
Still holds a freeze protection of -27*F = -33*C
http://www.engineice.cc/index.html
Re: New solution to your overheating!!
« Reply #1 on: May 21, 2009, 09:39:10 PM »
Can we get this anywhere in the city?  Id be willing to be the test for this since Im installing an efan as well.
Offline jandh
« Reply #2 on: May 21, 2009, 09:46:58 PM »
WOW at $79.89 USD for 2 Gallons you may want to reconsider and find the problem with you jeep
http://www.engine-ice.shops.sponsorhouse.com/catalog/
1991 YJ
FullMetalJeep
« Reply #3 on: May 21, 2009, 09:47:30 PM »
I want to talk to my buddy's at NAPA and see if they will bring it in. I got them to stock Royal Purple, so who knows. I heard it is expensive though... but can you put money on gasket or coolant leaks? How about warped heads? or maybe if your like me your sick of looking at your fricken heat gauge 50 seconds out of every minute?? let alone the toll the environment takes every time more toxic coolant is produced?!
no word on the price yet, but I will see how much more I can find out.
FullMetalJeep
« Reply #4 on: May 21, 2009, 09:48:46 PM »
vs the $450 USD 3 stage core aftermarket radiator Im looking at...
Offline jandh
« Reply #5 on: May 21, 2009, 10:03:36 PM »
well it's always cheaper for the fluid rather then changing parts, thats a given -
so just to help out a bit
13 quarts( average coolant cap) is 3.25 gallons
and the price is $90 CAN for 2 gallons
so you need 4 gallons ordered
$180.00 in Engine ice(plus shipping) and you'll have a bit left for top ups :P
Coolant is expensive no matter what (to me)
If you end up getting this let me know how it work, I've heard it's great in ATV's
1991 YJ
« Reply #6 on: May 22, 2009, 10:02:16 AM »
Which one are you looking at?  I got my Extreme Rad heavy duty 3 core for about $350 CDN
FullMetalJeep
« Reply #7 on: May 22, 2009, 10:11:18 AM »
I am looking at a company called FlowKooler I saw in a JP mag add section. direct bolt on replacement w/ all brass, copper and steel.
Offline JENSSEN
    • Racing For The Cure
« Reply #8 on: May 22, 2009, 11:01:13 AM »
2 Things that caused my Jeep to get hot, one was the ballast resistor, made it run lean (hot) and the other was heater hoses, and small little issues that did not allow it to pressurize properly,... it was way less than $180.00 to fix,.. just my 2 Cents
www.racingforthecure.ca
« Reply #9 on: May 22, 2009, 11:23:15 AM »
fraser i have a solution. lets put heat vents (like on teh 5.9) in your hood. bring down ur runnin temp 20 degrees.
its ok, all we have to do is saw holes in your hood. i'm pretty handy with a sawzall :D :D :D :D
FullMetalJeep
« Reply #10 on: May 22, 2009, 01:14:35 PM »
actually I just did that and it doesnt do anything. A vent w/ 1 square foot hole underneath. I was in the process of putting some other vents in the hood when I put my hole in the rad..  ::) idiot! oh well, I figure I'd have to get a new hood to replace my current hood that has that stupid tiger painted on it anyways.
Offline rws
  • Stump Grinder
« Reply #11 on: May 22, 2009, 01:17:16 PM »
Hesco makes a high flow water pump similar to the FlowKoller, more expensive but better quality.
I have one, works great.
« Reply #12 on: May 22, 2009, 05:27:14 PM »
The dirtbike world has mixed reviews regarding this "ICE".
Think about it, your cooling system hits a certain 'danger' temp and the symptom of overheating becomes visible...rad steam.
Now you put something in the system that raises the boiling point so the symptom does not become apparent. How much stress is the rest of the engine/system under now that you have removed the warning?
My bikes never run it for that reason. Ironically, i bought a FAN for my bike. It only comes on when things are too hot. Using ICE messes up that warning system.
So, if it were me with an overheating 4x4, i would check the following:
Water pump
Clutch fan (replace with electric)
Rad...are the fins blocked?
etc.
FullMetalJeep
« Reply #13 on: May 22, 2009, 05:56:44 PM »
for sure, that is quite plausible. When I change out my rad I will also do my pump and thermostat.
« Reply #14 on: May 22, 2009, 08:29:20 PM »
My Extreme Rad is a brass, copper, steel core and it almost 2" thick, compared to 1-1/4" stock core, and it supposed to be a direct bolt-in but I will let you know after tomorrow
