Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
General Talk
front trackbar
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: front trackbar (Read 1946 times)
Corey
Guest
front trackbar
on:
May 30, 2009, 04:39:29 PM »
Has anyone here used the front trackbar relocate bracket found on eBay? Its 50 bucks insted of 250 for the adjustable trackbar.
Logged
WhiteOut
Talks waaay too much!
Re: front trackbar
Reply #1 on:
May 30, 2009, 05:34:24 PM »
The relocation brackets are pretty weak compared to the adjustable track bars. Save up a bit more and do it the stronger way
Logged
Corey
Guest
Re: front trackbar
Reply #2 on:
May 30, 2009, 06:16:04 PM »
That's what I was gonna do but it is killing my front tires! Gonna get the braket till I can afford the trackbar. Thanks for the imput
Logged
cablesmurf
Relapsed Jeep Addict
Re: front trackbar
Reply #3 on:
May 30, 2009, 06:46:49 PM »
Just do the drill and move over method until you can afford a new trackbar. Some will argue that this method is weak and if you don't get the bolt tight enogh it can oblong the new hole.
I wheeled the hell out of my first TJ with the TB like this and never had a problem with it. Just make sure to get that mo-fugger tight.
This was on my '89 XJ (same idea):
Logged
Hi, my name is Dan and I'm a Jeepaholic
Corey
Guest
Re: front trackbar
Reply #4 on:
May 31, 2009, 04:26:33 PM »
Someone elese also told me that as well
Logged
raf2379
That CB Yapper
Re: front trackbar
Reply #5 on:
June 02, 2009, 08:02:12 PM »
Corey
I just upgraded my whole steering system on my XJ including track bar so I have the RE1600 track bar i can part with, let me know if you want it. i'm in China right now but coming to Calgary on June 5th, PM me for details.
Logged
S-FLY
Budget Lift
'94 XJ
Re: front trackbar
Reply #6 on:
June 06, 2009, 11:56:13 AM »
I used the relocation bracket and sometimes it can be a pain in the arse because you have to retorque it all the time when the steering gets thrown off a little. Also noticed when I wheeled it once the bracket started to crack so I had to reweld it. Since welding it and torquing with a breaker bar, it's given me no trouble since.
Logged
ve1sly
Corey
Guest
Re: front trackbar
Reply #7 on:
June 06, 2009, 10:45:45 PM »
Trackbar instaled. Talk about knocking out my steering wheel!
Logged
raf2379
That CB Yapper
Re: front trackbar
Reply #8 on:
June 07, 2009, 06:42:27 AM »
did it fit good with the 2" lift? did you end up using the bracket as well?
Logged
Corey
Guest
Re: front trackbar
Reply #9 on:
June 08, 2009, 04:26:33 PM »
No need for the bracket with the Tj had to drill out the whole a bit for the bolt to fit but feels much beter. Steering wheel is out half a turn can't see the speedo or tac lol gonna fix that tonight
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
General Talk
front trackbar
