Author Topic: T case drop question  (Read 3032 times)
Corey
« on: June 24, 2009, 11:56:58 AM »
Can you just use 1" spacers or do you need to put a whole 1" bar drill holes and longer bolts?
Offline fug
  • Airdrie Pick n Pull
Re: T case drop question
« Reply #1 on: June 24, 2009, 12:58:45 PM »
You can use washers/spacers/bar whatever you want with some longer bolts to make a tcase drop
Fug
TJ Rubicon
Corey
« Reply #2 on: June 24, 2009, 02:45:42 PM »
Now what size and where can I find longer bolts that won't break under pressure?
Offline Crunch
« Reply #3 on: June 24, 2009, 06:57:36 PM »
National 4x4 has them-$70.00 for the spacer kit
Offline Mudhawg
  • Rig Life
« Reply #4 on: June 24, 2009, 10:35:50 PM »
i have the blocks sell em for cheep
« Reply #5 on: June 24, 2009, 11:43:56 PM »
why are you thinking about a T case drop
are you having vib issues or are you lifted
maybe theres another way like a 1.25" body lift and a 1" motor mount lift will help reduce vibs
Corey
« Reply #6 on: June 25, 2009, 10:37:25 AM »
I have a 2.5"lift and a 2" body lift and the drive angles are causing me to tear out my transmision mounts and causing lots of vibrations!
« Reply #7 on: June 25, 2009, 06:03:17 PM »
well i would consider a motor mount lift then if you already have the body lift . mine as well keep the skid plate as high as you can since we all know how low they hang
im running a 4" suspension 1.25" body lift and a 1" motor mount lift and a stock drive shaft and all is good
« Reply #8 on: June 25, 2009, 06:03:40 PM »
rough country sells motor mount lifts for 50 bucks .
Corey
« Reply #9 on: June 25, 2009, 08:38:13 PM »
Wouldn't a motor mount lift cause the fan to hit the shroud?
« Reply #10 on: June 26, 2009, 07:02:09 AM »
not if you have a body lift .. what kind of motor do you have 4 or 6 and have you moved your shroud when you did you body lift
Corey
« Reply #11 on: June 26, 2009, 10:29:16 AM »
I have the 6 and the body lift was done when I bought the jeep
